So i just got my samsung fascinate. It was running really laggy so I decided to root it and install a different ROM. (Superclean). Rooting was successful. I installed ROM manager and downloaded superclean. I followed the ROM manager's instructions for installing the ROM. The phone rebooted once it rebooted I was faced with a white triangle with yellow exclamation mark and an android figure. I figured out how to get into the manual recovery. The only options I have are reboot system (if i do this I get stuck on the verizon wireless banner flashing), apply sdcard: update.zip, wipe data/factory reset, and wipe cache data. If I try to apply update. I get an error message saying E:Can't mount /dev/block/mmcblk1pa (invalid argument E: Can't mount SDCARD:update.zip Installation aborted.
