triton.
So are there any Car chargers that will work as AC fro the nexus? This shouldn't be so hard to find.
Thanks DLC. So the Motorola one should work then here on amazon? Looks like it gives .95 amps, which is better than the .5 amps that most will give. Do you have a link for the verizon one, or is that just the one they sell at the stores?
Amazon.com: Motorola Vehicle Power Adapter micro-USB Rapid Rate Charger: Cell Phones & Accessories
The Motorola car charger shows as AC in the menus during charge, not USB.
Sent from my A500 using Tapatalk
Did some research myself on car chargers and found that this one will do "AC" charging on the gnex with a regular micro USB cable:
HTC oem car charger @ amazon
I have been using these for years. They are cheap, and they work very good and don't destroy your battery like some car chargers will. Also it has a nice blue glow. Give it a shot it's less than 5 bucks.
This charger show up as "A/C" on my Nexus as well as the "Just Wireless" SKU 03158 at Walmart
Walmart.com: Just Wireless Micro USB Mobile Car Charger For Motorola and other phones: Cell Phones
Great find! The reviews all indicate that it is wired properly for full current delivery.
Does your post mean that you actually have one, use it with a Galaxy Nexus, and that it is shown as "AC" while charging?
Yes I picked up two from the link above and they definitely show AC charging on the gnex. Note the cable is not included only the charger itself. But it works fine with some cheap monoprice micro usb cables.
