Results 1 to 4 of 4
    Default Spare Battery Charger Issue
    I bought 3 of these and all have the same issues. Whenever I charge my extended batteries in these the green light always goes on prematurely before the battery is at 100%.
    Anyone have a workaround on this?
  2. #2
    Default Re: Spare Battery Charger Issue
    Ive noticed the same thing. It says its done but it will only be like 97%
  3. #3
    qnet's Avatar
    Posts
    Global Posts
    1,443 Global Posts
    ROM
    All stock right now
    Quote Originally Posted by byrds8 View Post
    I'm starting to think that's a Samsung thing. When I had the Nexus S it rarely showed 100%. It always showed 97-98% after charging. I can get the G-nex to show 100% but, I have to put it back on the charger immediately after removing it or take it off the charger right when it's fully charged. It doen't last long on 100%. either.
    I read somewhere that when the phone gets fully charged and, it's still on the charger, it wil discharge a little. I forgot the reason I the does this. I think it has something with not ruining the battery.
  4. #4
    It does have to do with not ruining the battery. Lithium batteries dont require over charging due to memory like the old NiCads did. Once it hits 100% it stops charging and starts discharging. After it reaches a point it will charge again to full and repeat the cycle. Ive pulled batteries off after it hits 100% though and slap it in the phone only for it to say 97-98%.
    As for not lasting long at 100%, since I turned off touch sounds and lock screen sounds it seems to last a bit longer than it did prior.
