Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By bamaboy
    Default Does the expandable battery fit the double case made by incipio?
    Curious because I'm about to order the extended battery and wondering if I'll need to exchange for another case or not.
    Because I really like this case.
  2. #2
    KoukiFC3S's Avatar
    Android Connaisseur
    Posts
    Global Posts
    2,431 Global Posts
    Default Re: Does the expandable battery fit the double case made by incip
    It bulges out a tiny bit, but it's almost unnoticeable.
  3. #3
    hapbeeboy's Avatar
    Posts
    Global Posts
    42 Global Posts
    It does, but there is a slight "gap" between the soft silicone inner case and the hard outer shell, you can see in this video:
  4. #4
    monsterenergy22's Avatar
    Posts
    ROM
    Stock, Overcome 2.0
    Returned my today but it does work, and like others have said there is a slight gap at the corners.
  5. #5
    Default
    What about nfc
  6. #6
    You can use the standard battery cover instead of the extended and get it looking a little bit better. There is still a slight gap, but not as big as with the extended cover. Barely noticeable and you still get the benefit of a little more juice. I am not one for big bulky extended batteries, so I have never purchased one before.The thunderbolt I had before went from a brick to well, a bigger brick.
    Case aside, I think the phone feels much better with the extended battery and cover. Its a lot better to hold and is more evenly balanced.
    IMO, for the price and the little if any downsides, I don't see why you wouldn't go for it even if it is a minute difference in run time.
    NateDizzy likes this.
  7. #7
    moosc's Avatar
    Grand Master Moosc
    Posts
    Global Posts
    5,027 Global Posts
    ROM
    AKOP M4 old geezer theme
    First dont use stock cover on extended battery. The added pressure will push on the screen causes issues. Second yes nfc wallet and beam work.
  8. #8
    NateDizzy's Avatar
    Posts
    Global Posts
    74 Global Posts
    Quote Originally Posted by moosc View Post
    I havent noticed any issues, how did you come to this conclusion? Not being a *****, just wondering.
  9. #9
    moosc's Avatar
    Grand Master Moosc
    Posts
    Global Posts
    5,027 Global Posts
    ROM
    Default
    From experience and come since. U have a screen u have board then battery slot u place pressure on battery that pressure has to go some where it goes to the board that then is pressed up against display. You are also causing pressure on battery tabs those are the weakest link and could snap.
    Quote Originally Posted by NateMob@gmail.com View Post
    Google Nexus Class Devices (Nexus7, Nexus4, Galaxy Nexus lte VZW)...@moosc on twitter ...
  10. Thread Author  Thread Author    #10
    Default
    I ended up exchanging the case. The little gap on the hard part of the case was annoying the heck out of me.
    I ended up getting the black glossy silicone case. To be honest, I like it better. Gives it a sleek look.
  11. #11
    Default
    Does nfc work with incipio
  12. #12
    moosc's Avatar
    Grand Master Moosc
    Posts
    Global Posts
    5,027 Global Posts
    ROM
    Default
    Yes it does I use Google wallet no issue
    Quote Originally Posted by thirsty1258 View Post
