isosunrise
I am currently only on the 2nd cycle charge cycle of Seidio's 3800mah. For the 1st charge cycle, I got two days of usage with 4G/GPS on (I have great 4G coverage in San Francisco, connected to 4G 99% of the time). I literally had to drain the remaining 20% battery by leaving the screen on and streaming Pandora on the second night so I can charge the phone overnight. I am a heavy texter, emailer, and internet browser, but probably only use 30-60m talk time per day; I have two email accounts that are pushed, 4 other email accounts that check every hour, most of my Google stuff is auto sync, and auto brightness. In comparison to the Samsung's 2100mah battery, I typically have about 20-30% left at the end of the day, so essentially the Seidio is indeed double. I am sure the battery life will be longer after a few charge cycles. Also, if I had use wifi instead of 4G, I probably might make it to 2.5-3 days! I was using 4G only just so I can "drain" the phone faster. Will keep you guys posted.
Skyboxer, the battery is just a thicker battery (think double)... so if you find a thick enough case, you shoudl be able to modify it as before. I believe Seidio also has a case for the 3800mah, but I carry all my phones bare, no covers, no cases.
