Page 16 of 25 FirstFirst ... 13141516171819 ... LastLast
Results 376 to 400 of 623
Like Tree62Likes
  1. #376
    mikemck's Avatar
    Posts
    Global Posts
    46 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [GUIDE] Galaxy Nexus MOD/Palm Touchstone-No soldering on phon
    Speaking of magnets, there is another thread about Tetrax magnetic mounts.
    On the Tetrax website there is an interesting video about why they use 4 magnets together rather than just one. I don't understand why it is so, but with one magnet holding the mounting disk there is still magnetic attraction to other things. With 4 magnets holding the disk there isn't any attraction to other things.
    This may, or may not, be relevant to how our 4 or 8 magnets could affect the compass or other phone stuff.
  2. #377
    Step666's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hmm, first attempt works but can't get the (extended) battery cover to fit with the extended battery - so currently using the stock battery and the extended battery cover.
    Thankfully, when I ordered the extended batter, I ordered a second cover with it, so I think I've worked out where I went wrong and should be able to adjust my methods with the second cover.
  3. #378
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just wanted to say a big thank you to the OP and the rest of the folks in this thread. I was able to successfully complete this mod.
    The biggest difficulty I had was making sure that the battery cover came into good contact with the phone. If you put it all together and it's not working, definitely check your connections one piece at a time. I found out the hard way that the copper tapes inside the phone weren't as solid as they should be so I had to take apart the phone again.
    Here are some additional hints to try to help out other folks, esp the more novice electronics folks:
    • Learn to use the continuity function of your multimeter to make sure all of your tapes and connections are good.
    • Before putting the phone back together, test your copper tape connections by using the continuity function. The easiest way is to put one probe on the appropriate external pogo pin on the outside of the back cover and the other probe on your copper tape where it's wrapped around to the other side. This will ensure you don't have to take apart your phone again.
    • Also before putting the phone back together, put together the battery cover (with the inductive coil already installed) with the back cover and use the continuity function to check that you have one continuous circuit from the pogo pin all the way to the inductive coil.
    • The foam suggestion is pretty important. Go ahead and use half of the foam for each tape. I do wish I had more foam to use on the battery cover side and automotive foam is pretty expensive so I just ended up winging it with some extra folded bits of copper tape instead. That doesn't work as well as foam but it'll do.
    • If you have it, needle noise electronics tweezers would be very helpful, esp for those of us with less dexterous fingers.
    I used an extended battery with the extended battery cover and although the fit is a bit tight and there is a tiny opening near the camera, the cover closes and I can live with it for the sheer coolness of this mod.
    I used 4 of the stronger magnets that the OP listed. On the desk, it works perfectly. However, if you plan on mounting the Touchstone vertically (e.g., in a car), you'll need more magnets. With only 4 magnets, the phone definitely will not stay on the Touchstone vertically. Simply holding the Touchstone vertically with the phone on it and very lightly shaking the combo will cause the phone to fall off.
    Issues that I currently have:
    • It seems that the stronger magnets screw up the compass as the compass app goes haywire with the cover on. There were some comments out there regarding magnets that might negate that issue but I haven't had a chance to review those comments.
    • I haven't gotten the Touchstone to work in my car yet. The same cable/touchstone works at home but not in the car. [SOLVED] Per the recommendation of another post later in this thread, I picked up the Palm Car Charger and the Touchstone works perfectly in the car now.
    • Sometimes, the Touchstone doesn't initiate charging. In those cases, I plug the USB directly in the phone, see that it works, then plug the USB back into the Touchstone. I'm not quite sure why this happens.
    ohiomoto and Pr3mier like this.
  4. Thread Author  Thread Author    #379
    ohiomoto's Avatar
    Posts
    Global Posts
    820 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for contributing. I agree about the foam. I've been experimenting with using foam on both sides of the connection and though it's pretty tight, It does make a more reliable connection. I'm starting to think that it may be more beneficial to use the foam on the back cover than the phone. It would be easier to double up the copper tape on the phone and then use the foam on the back cover. Ideally we want the best connection without adding any unnecessary thickness.
    A couple of notes on the charging. With some ROMs, it can take 10 seconds or more for charging to start. Also, every once in a while is seems as though it need to move the phone slightly to get the charging started. Not sure why this would help, but I think it does. The last thing would be to try another charging block in the car. Maybe the one your using doesn't put out enough juice.
    Pr3mier likes this.
  5. #380
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You're welcome. Just wanted to give a little back.
    I haven't gotten around to adding a custom ROM and I'll have to order another puck so either of those may be the issue with charging in my car.
    Generally speaking, I found that the phone charges almost immediately. Well, the little lightning bolt shows up almost immediately and the battery widget shows charging soon after. In cases when charging wouldn't occur, which thankfully is actually pretty rare at this point, I tried moving it around as you suggest because I thought it was a contact issue but moving around the phone wouldn't help. I even tried pressing down on the battery cover with the assumption I'd get a better contact but that also wouldn't help. In those cases, so far, doing the plug directly into phone, unplug phone, and plug into touchstone procedure works right away.
  6. #381
    Knolly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I finally got an extended battery cover to get this mod working (I couldn't get everything to fit with the standard door).
    The charging definitely works, however sometimes it will start charging for a minute or so and then stop... Has this happened to anyone else? I'm on a GSM Galaxy Nexus running Kang milestone 4. I'm going to try to roll back to stock since I know the software can affect charging as well and see what happens.
  7. Thread Author  Thread Author    #382
    ohiomoto's Avatar
    Posts
    Global Posts
    820 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sounds like it could be the contacts on the back cover. Try "pinching" the phone by the pogo pins and see it that gets is going.
  8. #383
    Knolly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ohiomoto View Post
    I readjusted the copper strips on both sides and added some foam and now it charges perfectly! Success!!!
  9. #384
    eventnick's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    FYI for those trying to use an NFC tag on top of the Touchstone like I was for initializing a Car Mode type automation....
    1) using an unshielded tag directly on top of the touchstone will destroy the tag. I do not know why I was surprised by this... pretty much the touchstone induces a large current in the loops of the unshielded tag and well you know, does bad things. So don't put an unshielded nfc tag on the touchstone.
    2) Using a shielded tag directly on the touchstone... (a) prevents the touchstone from charging if its occupying too much surface area (b) causes the tag to read continuously on-off-on-off .. due to interference from the touchstone (speculating).
    So pretty much you can have the NFC tag hanging off one side of the touchstone (mine is 30mm in diameter) which ...looks ret@rded and prevents you from triggering the tag if you put the phone in the opposite orientation.
    Looks like my dreams of having the touchstone charger in my car with an NFC tag triggering bluetooth etc automatically (and looking nice), dashed by a good old fashioned catch-22.
  10. #385
    freeskier44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by eventnick View Post
    Dang this sucks..... this was my next project.... shoot. There has to be a way....
  11. #386
    Knolly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My workaround was I just put a tag on my dash that I quickly hold my phone over before putting it on the Touchstone. By no means perfect, but still at least a bit more convenient than opening up the apps manually.
  12. #387
    ellesshoo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have been using tasker for months to start Bluetooth when connected to power, have it automatically turn off if not paired for within 20 seconds, and leave it on if it is paired but power removed (like if I grab it off the touchstone to do something while music is playing). It's perfect and doesn't require any manual intervention to turn it off or on when starting/leaving the car, no need to even swipe a tag.
    Also, I think most people would be very surprised how little power is used by bt just being in standby all the time (same with wifi). I know there are a lot of OCD types that just can't deal with it but it's true. I'm a little less OCD than most, I mostly set things up the way I did simply because I could (w/ insignificant hassle).
  13. #388
    Pr3mier's Avatar
    Posts
    Global Posts
    165 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by ellesshoo View Post
    I have been using tasker for months to start Bluetooth when connected to power, have it automatically turn off if not paired for within 20 seconds, and leave it on if it is paired but power removed.
    Can you please tell me what profile you use to set up this action? Or send me the backup? I know I can turn on BT when it is being charged, but when I take it off the touchstone it turns off BT. I didn't set any exit task for it.
  14. #389
    ellesshoo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by googly View Post
    I took a bunch of unrelated personal stuff out but this should still work. Contains 2 profiles with unnamed tasks and a named task.
    Pr3mier and todini like this.
  15. #390
    gobigred303's Avatar
    Posts
    Global Posts
    37 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am really struggling. I can't figure out what I'm doing wrong. This is the first time I've ever tried to do a mod like this, and the first time I have ever soldered something. I may be in over my head.
    For some reason, my multimeter shows no continuity between my top pin and bottom pin. Is this normally? It isn't my multimeter because I tested it on a 1.5v battery and it gave the correct reading. When I use the multimeter on the pins I get a steady 1 mV. I'm also not getting any continuity on the coil by itself? Is it possible that my 3 pin charger is broken AND my coil is broken? I doubt it. I'm probably doing something wrong. Any ideas? Better yet, anyone in the Denver area that can help me?
  16. #391
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoBigRed View Post
    An easy way to test your coil: Put it together the way it is supposed to on your GNex battery cover. Make sure that the black tape/foil that covered the coil originally on the Pre cover is installed as it won't work without that black tape/foil. Once all together, put the GNex cover with coil on the touchstone, making sure your touchstone is plugged in, and test the voltage across the two leads. You should be reading about 5V. Check that first since it's easy.
  17. #392
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This might help... here's a good video to watch regarding soldering to make sure you're doing it right:
  18. #393
    eventnick's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok. I have some more useful tech data to add. This is for folks who want to be able to use Force Fast Charging (FFC) or AKA AC Charging mode on the touchstone in their cars primarily. But it also applies to people trying to use non-OEM wall chargers as well.
    Ok so I am not sure where to begin this rant so I will just word vomit it out. If you want to use the Touchstone in your car the charger/cable you use is important depending on which charging mode you want to utilize.
    Background info:
    The TS needs more current to function than a lot of chargers can provide - which is why they tell you not to plug it into your computer and why it won't work with a lot of chargers. I am going to tell you why and how to work around or avoid the problem. If you do not have enough current to the Touchstone it will do a weird on/off/on/off dance. The touchstone looks for a charger/cable combination that indicates the data pins D+ and D- are shorted together - this is used by the USB Spec to indicate a charger that is capable of providing >500 mA. If you do not have this, then the touchstone will not work at all. This is done internally for the OEM Palm Chargers. If you have an amperage-capable charger you can short the pins together yourself and it will work ***however*** it depends on which mode you want to charge with. There are two modes, USB Mode (slow - ~ 450 mA to phone - sometimes inadequate) and AC Mode (fast ~ 650 mA to phone - much better but not as good as a good car or wall charger plugged in directly ~1000mA).
    If you are just wanting to charge your phone in USB Mode on the TS: my 850 mA Motorola Car Charger is adequate. I am guessing that you need at least a 650 mA rated charger. Remember it must have D+ and D- shorted to work at all.
    If you desire to use AC Mode on the TS: You need a charger capable of 1A. My 850 mA Moto Car Charger just causes the TS to on/off/on/off every few seconds. Remember even if the charger is rated for 1A it must have D+ and D- shorted to work at all.
    Here is a list from the WebOS forums that lists working CAR and WALL chargers for the TS: Here
    For my Car TouchStone -I have purchased the Palm Car Charger 3453ww which is 1000ma rated from Amazon for $12. This already has D+ and D- shorted internally. Here @ Amazon Plus its OEM so quality of the power delivered will most likely be much cleaner.
    I hope this is useful to folks who can't get it working in their car especially with the FFC (AC MODE) mod going. If you're seeing an on/off dance with the touchstone you are using an inadequate car/wall charger.
    ohiomoto and eandcent like this.
  19. #394
    matagilb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the idea i finally got this to work with my otterbox commuter case with extended battery.
  20. #395
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    What happens if I were to have the nexus connected to MHL and on the touchstone? Would it be safe?
  21. #396
    Posts
    Global Posts
    37 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by eandcent View Post
    Thanks for the tip. I tried this today and I'm still not getting a reading. Is there a way to test to make sure my multimeter is working by using the 3 pins on the GN? I think my coil might be fried or my multimeter isn't working correctly. I ordered another coil just in case, I'm super anxious to get this done. Thanks in advance.
  22. #397
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The easiest way is to use a regular 9V battery. The multimeter should read, as you might guess, 9V when you test the leads.
  23. #398
    piroko05's Avatar
    Posts
    Global Posts
    8 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I know this is buried and you most likely will not see this, but anyways....
    THANK YOU SO MUCH.
    This mod is absolutely incredible. It took me an hour and a half to implement and I am very satisfied with the results. The only thing I had to do a little differently was add some solder to the tape on the inside of the battery cover to ensure contact was maintained with the base (See here). Also, I lined up the copper leads while I had the enclosure off of the phone, it made it a lot easier (I didn't get a pic of this, sorry).
    ...now what to do with this extra 8m of Copper tape...
    ohiomoto likes this.
  24. #399
    Pr3mier's Avatar
    Posts
    Global Posts
    165 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    After recently updating to stock 4.0.4, I noticed that it takes about 11 seconds to indicate touchstone charging whereas it used to take only 2 seconds on stock 4.0.2. Just an fyi
    GSM gnex
  25. #400
    kuchar09's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This mod looks very simple!! I just have a question about voiding the warranty. Does this void the warranty because you need to open your phone? I ask this because I see no stickers around the housing for them to know that the housing was opened.
    As long as you don't solder the strips to the pogo pins I see no reason why this mod couldn't be undone for warranty replacement.
    Am I missing something?
