Page 17 of 25 FirstFirst ... 14151617181920 ... LastLast
Results 401 to 425 of 623
Like Tree62Likes
  1. #401
    ellesshoo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by kuchar09 View Post
    This mod looks very simple!! I just have a question about voiding the warranty. Does this void the warranty because you need to open your phone? I ask this because I see no stickers around the housing for them to know that the housing was opened.
    As long as you don't solder the strips to the pogo pins I see no reason why this mod couldn't be undone for warranty replacement.
    Am I missing something?
    I wish I could answer this for you but in all honesty it just doesn't matter bc there is really no indicator to trip by opening the phone. If you have a small diameter soldering tip I'd even recommend to go ahead and solder in the phone (a desolder wick with a little flux will clean it up like nothing ever happened if you need to reverse the mod).
  2. #402
    kuchar09's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [GUIDE] Galaxy Nexus MOD/Palm Touchstone-No soldering on phon
    Quote Originally Posted by ellesshoo View Post
    Ok thanks I was just curious... I order all the stuff so I should be able to do this by the end of week.
  3. #403
    freeskier44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Could some try this? What happens if I were to have the nexus connected to MHL and on the touchstone? Would it be safe? Would it charge faster?
  4. #404
    ellesshoo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by freeskier44 View Post
    I haven't tried MHL + touchstone but I have tried touchstone + power to USB port. It won't charge from both sources simultaneously, it will charge only from the first source that is connected. If you can force AC charging on the touchstone then putting your phone on it before attaching MHL should charge faster. Again, I haven't tried this specific scenario but I wouldn't worry that you will harm your phone
  5. #405
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by eventnick View Post
    For my Car TouchStone -I have purchased the Palm Car Charger 3453ww which is 1000ma rated from Amazon for $12. This already has D+ and D- shorted internally. Here @ Amazon Plus its OEM so quality of the power delivered will most likely be much cleaner.
    I hope this is useful to folks who can't get it working in their car especially with the FFC (AC MODE) mod going. If you're seeing an on/off dance with the touchstone you are using an inadequate car/wall charger.
    Thanks for the info. I picked up the Palm Car Charger and that solved my problem with the Touchstone charging not working in the car.
  6. #406
    gobigred303's Avatar
    Posts
    Global Posts
    37 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I tried this mod a second time, no dice. I ordered a new Palm Pre back and put it directly on the dock and couldn't get anything to show up on my multimeter. So I thought there might be something wrong with my multimeter (even though it is brand new and reads 1.5v and 9v batteries fine) and proceeded with the mod. I got nothing when I finally put my GN on the dock.
    Any advice? Contemplating giving up. Is anyone interested in buying 3 charging docks, 2 wall chargers, 8 magnets and a car charger?
  7. Thread Author  Thread Author    #407
    ohiomoto's Avatar
    Posts
    Global Posts
    820 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You should have seen 5.6 volts with the stock Palm battery cover. You have a problem with the dock or the wall charger that powers it and you have plenty of both. You can't get any of them to give you juice? Are you sure that outlet has power? Maybe a GFI needs reset?
    I would take the Battery cover off of the GN and place it on the dock and test different wall chargers, cords, docks and outlets until you get something. If you get nothing then I would say you have a bad coil in from the Palm battery cover.
  8. #408
    Posts
    Global Posts
    37 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the quick reply. It seems I may have another bad coil. I tried multiple combinations of cables, outlets docks and USB charging adapters. Very frustrating.
    I could be doing something very wrong. This was my 2nd coil, thought it was the coil the first time. I have 2 battery covers. If I send all my parts, is anyone willing to try this for me if I pay shipping?
  9. Thread Author  Thread Author    #409
    ohiomoto's Avatar
    Posts
    Global Posts
    820 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It seems crazy that you have all of those parts and none of them work, but there isn't much you can do wrong with the back cover and it appears that you haven't had any luck with that part. There is no way of knowing if the rest of the mod works until you know you are getting current through the coil.
    I guess the thing to do is test the docks and chargers with a phone that you know works. Do you ow anyone with a Palm phone?
    I could probably help, but I will be going out of town on the 15th so you would have to send the stuff out out soon. Send me a PM if you want.
  10. #410
    Knolly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm dittoing the recommendation to try a different wall charger. I thought I had broken two different coils and it turned out I just wasn't using a good enough charger.
  11. #411
    lu270bro's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ok so i have been trying to get this mod to go for me and keep running in to a problem. when I set the battery cover only onto the TS i get 5.6mv, and i can hear a high-pitched buzz when i stick my ear near the coil. when I stick the battery door onto the phone and place on the TS, the phone does not charge, and I hear the high pitched buzz, but it sounds like it is cycling. So, I took the battery cover back off and sacrificed a usb cable and soldered directly from the coil leads on the cover straight to the leads inside the phone where pogo pins would make contact, like this.... Galaxy Nexus inductive charging mod - [H]ard|Forum (2nd pic down). I still get the cycling buzz like its trying to start charging but cont or wont. Not sure what is going on. I have used 2 separate TS wall chargers, and the wall charger that comes with my HP Touchpad, which has a greater output. Any ideas what might be the problem? any help would be appreciated.
  12. #412
    Knolly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is the buzz going on and off or is it constant? From my struggles before getting this to work, a buzz going on and off means that the charger isn't getting enough power to charge.
  13. #413
    timinator94's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lu270bro View Post
    I have the exact same problem. I put my multimeter (of the el cheapo variety) on the connectors and I get a pulse that spikes up to 2 volts. I have tried 2 different coils and touchstone docks. When I put the coil in my battery door I get nothing.
  14. #414
    lu270bro's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Knolly View Post
    Constant when it's the door only, and cycles when the door is put on the phone
  15. #415
    todini's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I took a bunch of unrelated personal stuff out but this should still work. Contains 2 profiles with unnamed tasks and a named task.
    Thank you so much!! I was trying to do the same thing, but i'm really unfamiliar with Tasker; Your file worked perfectly!!
  16. #416
    Knolly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wanted to mention to everyone, I tried out spraying my rear cover with Plastidip and it's awesome.
    For those that don't know, Plastidip basically sprays rubber. So I put a few coats on the back of battery cover and it grips to the Touchstone incredibly solidly and it gives it a nice matte black finish.
    Best part of Plastidip: Don't like it or scratch it somehow? Just peel it off. The coating bonds ONLY to itself and nothing else, so you can just peel it off the cover and it'll look good as new.
    ohiomoto likes this.
  17. #417
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by timinator94 View Post
    Still having this issue :/
  18. #418
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you don't mind, could you post a picture of what it looks like with the Plastidip? Thanks in advance!
  19. #419
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm not quite sure what is going on but if I'd suggest taking things at a real step-by-step snail pace to see where along the line something is messing up, starting with known situations. To ensure that your coil/dock is not broke, start with them fresh out of the packaging. Put the unassembled Palm door onto a touchstone dock and use the multimeter to check the readings. You should get a steady 5V reading. If you do, then you are sure that the plug is providing the appropriate current to the dock, the dock is functional, and that the coil is functional. I'm not sure how familiar you are with electronics but this should give you a nice baseline of expectations.
    Once you do that, carefully take out the coil and then put it onto your GNex battery door. Again, remember to also bring with it the black coil cover that originally covered the coil on the Palm Pre battery door as the coil won't work properly without the black coil cover. Once on the GNex battery door, put it onto the Palm Touchstone. The only thing you have done is switch covers so you should read 5V again. Try that out and then proceed from there.
    Maybe that will help? Nonetheless, if you find the issue, please do share with the rest of us as it seems that more than one person is having the same issue. Good luck!
  20. #420
    Knolly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by eandcent View Post
    Sure thing, here's a quick shot I took:
    dropbox.com/sh/g4r7j6e1aaveoy1/7fo3hKcSf9/2012-04-10%2013.07.30.jpg
    I scuffed it up a rubbing it into the touchstone simply to see how durable it is, but it's holding up great.
  21. #421
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, that looks good. Is that the extended battery cover or the regular one? On my extended cover, the "SAMSUNG" doesn't look raised but in the picture, the Plastidip preserved the outline of the word.
  22. #422
    Knolly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's the extended battery cover. The SAMSUNG is raised enough on the cover that it becomes more pronounced when you spray it with Plastidip. I'm thinking of sanding the whole battery cover to be smooth then respraying it to have a nice smooth and grippy finish. It looks and works great with the black TPU bumper as well.
  23. #423
    eandcent's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nice. How well does the Plastidip help keep the phone on the charger in the car? For me, I noticed the issue is largely the weight of the phone (and probably how relatively weak my magnets are) so the phone can slide off in an abnormal acceleration/deceleration. If you do end up sanding/respraying, do let us know how that goes. I'm curious to see how it works out.
  24. #424
    Knolly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The Plastidip is rubbery and grippy so it creates a LOT of extra friction to keep it on the dock.
    What I've actually started over the last day or so doing because I have two battery covers is I wrapped one in 3M Di-Noc to look like carbon fiber, and I have that on most of the time, then I keep the Plastidip cover in my car in case of long trips or something I can swap them to ensure it stays secure on the Touchstone.
    Like I said, I only just started doing this, although honestly, I somewhat expect I'll just start using the Plastidip cover all of the time. I just figured since I had some Di-Noc lying around and an extra cover I'd try it out, haha.
  25. #425
    strongergravity's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I did this mod the other day, putting the coil inside a case. I tried several methods to use the pogo pins to get the juice inside, including solder on sticky side of tape. It just didn't make a solid enough connection. I finally decided to pop the back off the phone and go that route. I extended the tape to the outside of the phone, up to the pogo pins. This way I can use a coil inside the door or inside the case. I can use whatever battery size I choose now.
    This mod is great! I have a TS in my car as my dock, plus one at home and one at work.
    Many thanks to Ohiomoto.
