- 04-28-2012, 01:45 AM #451
Re: [GUIDE] Galaxy Nexus MOD/Palm Touchstone-No soldering on phon
- 04-29-2012, 01:51 PM #452
I tried this mod today, and after removing the coil from the palm pre back cover and putting it onto my galaxy nexus back cover, I'm hearing this buzzing that goes on and off every second when it is placed on the palm touchstone.
Is this normal? Or did I break the coil when I was prying it out of the palm pre back cover?
EDIT: I'm using the standard Palm charger and cable that came with my hp touchpad - 04-29-2012, 02:34 PM #453
- 04-30-2012, 12:34 AM #454
- 04-30-2012, 06:49 AM
Thread Author #455
Silver sticker is there in the OP and I've never noticed the sound you described.
- 04-30-2012, 08:28 AM #456
- 04-30-2012, 08:41 AM
Thread Author #457
That's because it was still stuck to the black sticker as shown in the first picture. I don't know for sure if it's needed, but I'm sure Palm put it there for a reason. Why complicate things by not using it? You know what I'm saying?
Either way, the coil should produce 5.6v.Last edited by ohiomoto; 05-01-2012 at 06:33 AM.
- 04-30-2012, 08:45 AM
Thread Author #458
1) Not sure if it's normal because I never noticed this myself, but it is possible to damage the coil. Did you test it to see if it is producing 5.6 volts?
2) The Touchpad charger is NOT the same as the Palm charger. Produces twice the power. You should be using the Palm charger or the charger that came with the Galaxy Nexus. - 04-30-2012, 11:03 PM #459
I noticed my mistake - so it turns out i needed that silver piece of sticker.
first time I placed the sticker underneath the coil (between the coil and the back cover), and this caused 0 volts to go through to the 2 points.
next, i removed the silver sticker completely, and that's how i got the constant 1-second buzz sound, and i see it jump from 0 to 0.5v every second.
now, i put this silver sticker on top of the coil, and it worked! I'm getting a constant 5.6v!
thanks for the help, hope this info will help others that are trying this mod. - 05-02-2012, 03:06 PM #460
Thank you so much for this post. I just dropped my Nexus day demoing the phone to a customer (I'm a VZW agent). Samsung is charging me $163 to repair it which is much better than paying $258 for a replacement screen off of ebay.
Anyway my point is after I did this mod I quit using my commuter series otterbox b/c I couldn't find a case that would work well with the inductive coil AND hold on to it at the same time. I'm now ordering the case you recommended. Thanks again. - 05-04-2012, 10:16 AM #461
This may have been asked already, and if so I apologize for asking again, but is it possible to use the coil from the palm back with a different type of wireless charger, like one of the charging mats? These all work in a similar way, don't they? I've always liked the mats, but they don't make them for many phones.
- 05-07-2012, 09:24 PM #462
There are a handful of inductive charging protocols and I don't believe they are cross compatible. I'm almost 100% certain there are none that are compatible with Palm's touchstone system. For a higher degree of compatibility you may try a Qi coil & charger. It's one of the standards competing to be THE standard for inductive charging, however small that race may be, so you may be more likely to find a variety of compatible chargers in that ecosystem.
- 05-08-2012, 09:41 AM #463
- 05-08-2012, 11:10 AM #464
- 05-08-2012, 11:35 AM #465
- 05-09-2012, 08:12 AM #466
There is a solution to what you are talking about on webOS nation website. What you need to do is try using a business card and putting it on the touchstone, then place your Galaxy on it and see if the on off problem stops. You need to do a search on webosnation and you will find out what to do next. If you are getting voltage intermittant, then you did not mess up the coils, its just that with all of the Touchstones made, some of them have a slight flaw that make the coil too close in the inductive part in the touchstone, hence needing more separation (thickness of a business card) to prevent on off problems.
- 05-09-2012, 08:15 AM #467
I'm a Palm Pre user who just switched over to the Nexus after 3 years on WebOS. Just get an exacto knife and trim around it and then it will fit into the touchstone. No need for the official palm cable. I did this with 3 of the 6 touchstones I have accumulated over the past 3 years.
- 05-10-2012, 10:48 AM #468
If I put a continuity tool on the two outside pogo pins (ignoring the middle one) I only get a very short beep indicating continuity. I get a very brief beep when contacting the foil strips that wrap around near the battery (the contacts for the phone portion that come into contact with the back door).
I cannot for the life of me get a charge. I can hear the inductive coil working, I get continuity between the two foil strips on the back plate, etc. The door does bulge an awful lot right where they're making contact, but it certainly looks like they are making contact. I just can't tell...Last edited by Headcase_Fargone; 05-10-2012 at 02:27 PM.
- 05-12-2012, 01:12 AM #469
It is not a "silver sticker" it is a metal sticker. It is required. Do not remove it. It is a shield to prevent the magnetic field from energizing anything other than the inductive coils. You can potentially damage things in your phone if you remove that shield. USE IT. - 05-12-2012, 01:14 AM #470
- 05-19-2012, 07:31 PM #471
I did this mod in about 10 minutes this afternoon. I didn't use any solder and used an upside down Pixi coil instead. The phone is charging in A/C mode w/o fast charge enabled and everything seems to be working fine other than a slight bulge on the left side of the phone where the foam pads are. I think I may trim them down a bit.
Really easy and handy mod for under $20. Now I need some metal friendly NFC stickers to throw on the touchstones. - 05-22-2012, 11:52 AM #472
- 05-22-2012, 12:45 PM #473
The coil will interfere with the NFC when it is charging - electronic interference. I put an NFC tag on the underside of my dash - I just wave my phone in front of it before I mount it. I just got some NFC keychains from buynfctags.com. They were pretty cheap. I will use them in the future in the car.
- 05-22-2012, 01:38 PM #474
- 05-29-2012, 06:52 PM #475
OK so I have put mine inside a diztronic case. Last night I had the copper tape reading 5.6 on the multimeter and today it won't read past .2 I removed the copper tape from the coil and even re-soldered it. Still can't get 5.6 anywhere except at the coil itself. Any help would be appreciated.
Reply
