As an electrical engineer for over 10 years, I'm starting to lose my mind. I'm modifying my phone and bought a 2nd setup for a friend.
I have two of these:
Deep Discount for Brand New HP Touchstone Charging Dock Pre Pixi Veer Pre2 PRE3 | eBay
Six of these:
Amazon.com: Palm Touchstone Back Cover: Cell Phones & Accessories
I didn't even check the voltage to start out with. I just started transferring the coil to my phone, got the magnets down, put the palm sticker back over the coil/magnets, then plugged it in and checked the voltage. Nothing. I've now tried 3 different bases with my modded phone backplate and the other non-modified palm backplate. I've been trying to figure this out for an hour and I can SOMETIMES get a charge to show up. A 5.56 voltage corresponds with a constant buzzing. However, most of the time, I get no buzzing, no voltage. Sometimes I get a oscillating buzz/no buzz, but it doesn't stay around much, and I haven't gotten a voltage with it.
I've tried nudging the bare backplates up/down. I've tried lifting the backplate off the charger slightly. I've tried different usb cables (one of them I've been using to charge my phone for a long time now). I've tried plugging it into AC and a USB port on my computer. I've checked the voltage of the wall socket.
If the buzzing occurs, I can hold my ear up to the thing and rotate it. This changes the frequency and volume of the buzzing. However, it seems any time I change something (remove power, remove the backplate from the base) the buzz (and voltage) goes away.
It's extra frustrating because I don't know of a way to diagnose which part is defective, since it happens with 3 bases and 2 coils.
Any helpful ideas? I'm beginning to think I've wasted $100.
Edit:
I've also tried with the original magnets, with the stronger neo magnets, and without magnets. Whether or not it works is a crapshoot. I actually did get it working like 5 times in row with the original palm pre magnets after switching a power cable. Thought it was the cable after all, so I swapped back out to the neo magnets and it didn't work. Swapped back to the config that worked 5x in a row and it wouldn't charge at all. I've officially spent waaaaay too long messing with this.
