Results 1 to 8 of 8
- 01-21-2012, 09:02 PM
Thread Author #1
SGP Neo Hybrid Case Video Review (Silver)
Hope you guys enjoy!Current Device: HTC Glacier (MT4G)
Rooted, Overclocked to 1.8Ghz
Running Gingerbread 2.3.1 - 01-21-2012, 09:26 PM #2
Re: SGP Neo Hybrid Case Video Review (Silver)
Too bad that case doesnt fit verizon's nexus.
- 01-21-2012, 09:48 PM #3
i think it fits good enough, i have one on order to try and see
- 01-23-2012, 11:03 AM #4
- 01-23-2012, 11:18 PM #5
- 03-05-2012, 12:45 PM #6
- 03-06-2012, 12:08 AM #7
I was really bummed that these weren't fitting the verizon nexus as well with the extended battery, and then I came across the Box eave Unicolor Samsung Galaxy Nexus case, and it does the job beautifully. Now I did find that for it to fit well I had to use the extended battery with the standard battery cover, but this case essentially gives you a similar two tone look and overall I'm very pleased by it, if anyone cares to take a look as well. Also on a happy side note, it fits the seidio case holster
Sent from my Galaxy Nexus using Tapatalk - 03-08-2012, 06:17 PM #8
Reply
