Results 1 to 9 of 9
- 01-26-2012, 08:18 PM
Thread Author #1
Trying to Find the Spare Battery Charging Kit
Hi everyone, I have been trying to find the Spare Battery Charging Kit but Verizon does not have any more and I don't know where I can find it. If I have the SKU that verizon uses I could try to find it that way.
Any Help would be great.
Thanks - 01-27-2012, 12:23 PM #2
Re: Trying to Find the Spare Battery Charging Kit
If it was any closer it would have bit you on the nose.
http://www.shopandroid.com/samsung-s...tem/AA9636.htm - 01-28-2012, 11:16 AM #3
- 01-31-2012, 08:24 AM #4
Problem is that like everywhere else, they are sold out. This must be Samsung's fault if no one has them. I think it is really sad that Samsung is dropping the ball with accessories. I would buy this battery charger and a OEM car dock in a second if they had them!
HTC EVO 4G > SGSIIE4GT > HTC REZOUND > GALAXY NEXUS - 02-02-2012, 08:42 PM #5
- 02-04-2012, 05:02 PM #6
- 02-04-2012, 10:31 PM #7
DayDeal sells one on Amazon for $35 shipped. External charger, standard battery and wall charger.
- 02-04-2012, 10:34 PM #8
- 02-08-2012, 10:47 PM #9
Some VZW stores still have a few in stock. It's only the VZW online that's temporarily out.
Also, ones sold by VZW are different from ones being sold at phandroid store, amazon, ebay, and other resellers.
VZW version comes with y-cable but no charger, so you have to use the one that came with your phone.
As for others, it seems to be a re-packaging of Galaxy S spare charging set, with no y-cable but comes with a travel wall charger. I've seen these products inside Galaxy S Spare Charging Set packaging with 'compatible with i515' sticker on them. They are probably just re-using the 'dock' and the charger, and just swapping out the battery.
VZW version is 39.99, and other version is somewhere between 32~35.
Reply
