Seidio 3800 vs Mugen 3900 Extended Battery
mscalero
107
Hello,
Just wondering if anyone purchased the Seidio 3800 or Mugen 3900 battery for the Verizon Gnex? Wondering on a comparison of which one is better. Obviously the Mugen should be slightly longer with 100mah extra but I am also wondering about form factor differences etc...
Mike
I've got the Seidio 3800 with NFC only, so I can't really do a full comparison for you. What I can tell you is this: both will have similar form factors (think like a raised platform in the center of the phone) and greatly extend your battery life. The Nexus is definitely still pocket friendly.
As for which one is better, I would encourage the Seido with NFC. It's over $25 cheaper than the Mugen when purchasing it from shopandroid. If you don't need NFC, shopandroid sells the same 3800 mAh, for only $63 (approximately $35 less than the Mugen). 100 mAh isn't worth the charge up that Mugen wants.
richardschofield
