Just got my SLIM for the LTE Extended Battery. See my review here.
Rearth SLIM Case Samsung Galaxy Nexus Extended CDMA/LTE/4G - YouTube
Nice review. These are my favorite tips of cases. I love the phone naked but having a case gives me a little peace if mind. I think I'll order the metallic case. How long did it take for the case to arrive?
The one for the standard battery was made for the GSM version and if used on the LTE version, the top lip doesn't quite fit. But that doesn't matter, since the one for Verizon Galaxy Nexus fits both the extended battery and the standard battery.I'm wanting the standard battery slim case in matte black. Does anyone know if the matte black case has a rubberized type of coating or is it slick, hard plastic? I'm coming from a Droid X, and got used to the rubberlike coating it has.
How's the "new" case with the standard battery? They mentioned there's like 1mm of extra space...where is that? Where the battery is? Does it "rattle" around?
I know they changed everything to fit better, but I'd rather not spend $$ on a product that has the phone slide around willy nilly!
you use the standard battery and standard case. Nothing rattles around. Did you watch the review?
The website states there is one case on the description. You can use the extended and standard battery with the updated case. Hope it helps ya
https://www.rearthusa.com/verizon_galaxy_nexus_slim.html
