- 04-09-2012, 09:38 PM
Thread Author #1
- 04-09-2012, 10:41 PM #2
Re: Extended Battery With Otterbox Case
when i had it, it didn't fit at all
but some people said it fits with no issues
i'm still dumbfounded - 04-09-2012, 10:51 PM
Thread Author #3
- 04-10-2012, 12:11 AM #4
I have the 2100 mah extended battery and the Defender fits. I will say that I've accidentally broken two of the pieces that clasp together on one side from carelessly taking it apart so be careful. You can use your fingernail to depress the clasp to take it apart. Although bulky, it is a nice case and it keeps my mind at ease with the protection it gives. The screen protector takes some beauty out of the screen but I like the idea of the phone being sealed in from the outside. Also, while I'm not a fan of holstering enormous phones to my hip I did attach the holster to my bike to hold my phone while I ride. I hope this helps and ask more questions if you have any.
- 04-10-2012, 12:39 AM
Thread Author #5
- 04-10-2012, 01:18 AM #6
I use the same backpiece for both batteries without any problem at all.. I would think it would fit as long as you keep the original back cover.
- 04-13-2012, 07:46 PM
Thread Author #7
Reply
