Has anyone else received this case and noticed that it does not fit correctly? Particularly on the volume rocker side, it does not make it past flush of the screen so it does not provide screen protection when facing down. Also, this makes it hard to use the volume rocker since the cutout for it is so close to the buttons.
I would like to know if there is just a bad batch of these or I should return it and look for something else. My other incipio case fits very well.
