Results 1 to 19 of 19
- 05-14-2012, 02:56 PM
Thread Author #1
- 05-15-2012, 07:46 AM #2
- 05-15-2012, 02:08 PM
Thread Author #3
- 05-16-2012, 01:22 AM #4
Re: TPU Bumper Case on Ebay $5..Best Minimal Protection Case
Looks interesting. Very minimal but still seems like it will protect from drops due to the corner protection.
OP, how do you think it will handle being dropped? - 05-16-2012, 09:32 AM #5
Seems interesting but it says it only fits the GSM Galaxy Nexus.
- 05-16-2012, 11:16 AM
Thread Author #6
- 05-17-2012, 03:49 AM #7
- 05-17-2012, 05:00 AM #8
Hmm worth a try for less than $5
Sent from my Galaxy Nexus using Android Central ForumsMotorola Razr Maxx - 05-17-2012, 01:35 PM
Thread Author #9
- 05-17-2012, 01:36 PM
Thread Author #10
- 05-19-2012, 02:30 AM #11
Thanks! Ordered one.
- 05-21-2012, 10:19 PM #12
- 05-21-2012, 10:27 PM #13
- 05-22-2012, 08:13 AM #14
- 05-22-2012, 11:58 PM #15
I bought this for my wife. It looks great but is now in the garbage. The rubber rim fell off. I thought I could glue it back, but it was too difficult. Also it does not work with several docks.
- 05-23-2012, 01:27 PM #16
How quickly did it take to arrive in the US?
- 07-27-2012, 11:17 AM #17
- 02-03-2013, 08:03 PM #18
In case anyone else runs across this thread looking for a bumper case for the Galaxy Nexus, don't bother with this one. Within a month of receiving the case, it has broken. The case is designed with an opening in the top right corner. This leaves 2 small strips of the hard rubber to hold that corner together, which you can see in the photos on eBay. One of the strips on mine has broken, and I suspect that it won't be long until the other strip breaks, making the case useless. Sad, because it does work with the large Hyperion extended battery.
- 04-01-2013, 10:25 PM #19
Reply
