Do the GSM and LTE Cases fit the same on the Galaxy Nexus?
Gorilla
72
Question, since the models are slightly different (Verizon model being slightly thicker)
Will all cases sold simply as Galaxy Nexus case fit both the GSM and LTE models?
I havent seen any distinction when shopping for cases online.
I am thinking of getting a Cruzerlite case, but they only sell 1 version...
TheAssailant
195
27
It depends on how tight or flexible it is. Otterbox probably won't fit (they have special versions, I imagine) but silicone type cases should.
Sent from my VZW Galaxy Nexus using Android Central Forums
sfbates
298
80
www.twitter.com
Usually it specifies.
Look for the SCHi515. thats the verizon version.
The verizon version is thicker then the GSM version. I have purchased some cases that were GSM only nexus and they fit my CDMA one because they had some extra room, and then i have some TPU cases that were GSM and they dont fit my CDMA nexus at all.
Do some research and see if people are saying that it fits their CDMA nexus.
