Results 1 to 6 of 6
    Default Best case with extended battery?
    What's a good case that fits with the extended battery?
  2. #2
    Default Re: Best case with extended battery?
    Personally the case-mate "pop" case works best I think. It doesn't add much bulk while giving sufficient protection. I've looked into the commuter case but I've heard with the extended battery it doesn't line up quite right or there are "gaps" in certain places.
  3. #3
    That's correct. I have the extended battery on my GNEX with the Otterbox Commuter case and it doesn't quite fit exactly. The top lines up but the bottom of the phone doesn't. It doesn't interfere with the flaps for the charge port or headphone port but you can notice it. I've lived with it as long as I can which is exactly why I'm in this forum looking around.
  4. #4
    cadman's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    6,822 Global Posts
    ROM
    BB JB
    This is really late but I had the POP and no issues.
    I switched to the surface case from Seidio, but it's for the extended battery as opposed to their standard battery case.
    How to install an Invisible Shield
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  5. #5
    OEM extended or the after market 3800mAh extended battery?
  6. #6
    cadman's Avatar
    Posts
    Global Posts
    6,822 Global Posts
    ROM
    BB JB
    They make a case for both depending on which battery you use.
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
