Results 1 to 8 of 8
    Default Official Shop Baixt Slim Extended Battery 2800mah for Samsung Galaxy Nexus
    Anyone ever try one of these batteries for the Gnex? The battery is terrible and the 2100mah isnt much better. Searching Amazon trying to find a decent slim replacement. I know Banker is good, but I stumbled upon this one and I'm thinking about trying it because its cheap but I can't find any reviews. I like to read opinions on anything before I buy something no matter how cheap it is, so if there is anyone out there who has used this before please let me know if it blows or not. Thanks!
  2. #2
    Edwill86's Avatar
    Posts
    ROM
    Stock/Franco
    Default Re: Official Shop Baixt Slim Extended Battery 2800mah for Samsung Galaxy Nexus
    most people use the oem/oem extended because the after market batteries do not have NFC chips in them. if you dont care about that thern have at it. there are tons of cheap ones out there..but you wont see much difference out of them in the long run.
    good luck!
    Devices: Galaxy Nexus and Nexus 7
  3. #3
    Do you have a link for it? I'd kike to see it.
    http://www.amazon.com/gp/aw/d/B008YS...idcentral00-20
    This batt is supposed to be 2800mah so if that's true it should get me through the day no problem
  5. #5
    It says not compatible with Verizon GNex phones
  6. #6
    Quote Originally Posted by yosteve View Post
    Read again it says it works for the I515 which is the Verizon version of the Galaxy Nexus. The I9250 is the Google Nexus.
    If it is a Slim battery (which is supposed to fit under the stock cover) it is not possible to make a battery of this capacity within the same size without using extremely expensive materials. The best Slim battery i have found was the 2250mAh battery from Andida a Japanese battery maker. They can be found on ebay and maybe amazon. They actually last the whole day with avg use. I get a regular 3-4 hours screen time over a 20+ hour time frame.
  7. #7
    scubamike's Avatar
    Posts
    Global Posts
    29 Global Posts
    ROM
    AOKP B38/Franco R194
    Just to be clear, this absolutely does not work with the Verizon GNex. The battery is a different size than the GSM GNex. The description is wrong.
  8. #8
    Weirdly enough I was able to purchase one of the slim 2800's that said 2800 right on the battery. Doesn't work any better than my 2300 which leads me to believe that it was perhaps a typo.
  1. Battery life for sprint galaxy nexus
    By Luca_Blight in forum Sprint Galaxy Nexus
    Last Post: 01-12-2013, 03:36 PM
  2. 2200mAh Power Back Case External Battery for Samsung Galaxy Nexus
    By zedorda in forum Verizon Galaxy Nexus Accessories
    Last Post: 06-15-2012, 11:43 PM
  3. Is this typical battery life for the Galaxy Nexus?
    By Atranox in forum Verizon Galaxy Nexus
    Last Post: 02-18-2012, 07:38 AM
  4. Seidio Innocell 1600mAh Slim Extended Battery for HTC Thunderbolt
    By drummerman2008 in forum Thunderbolt Accessories
    Last Post: 04-02-2011, 12:50 PM
  5. Replies: 0
    Last Post: 11-05-2010, 04:34 PM
