Page 12 of 16 FirstFirst ... 9101112131415 ... LastLast
Results 276 to 300 of 398
Like Tree48Likes
  1. #276
    davidnc's Avatar
    Posts
    Global Posts
    8,984 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexu
    Yeah the worst part about Android SDK is getting it all setup(along with the drivers ),but once its done ,,,,its done .It took me 30 minutes to set it all up ,and about 5 minutes of using command prompt ,
  2. #277
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    7,529 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BB JB
    Quote Originally Posted by davidnc View Post
    yeah the worst part about sdk is getting it all setup(along with the drivers ),but once its done its done .it took me 30 minutes to set it all up ,and about 5 minutes of using command prompt ,
    exactly my situation!!!
  3. #278
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm working on getting you a new working link for super boot.. should have it posted in a little bit.
  4. #279
    trmoney24's Avatar
    Posts
    Global Posts
    423 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AXIOM 2.4
    what is the best way to unlock the bootloader and then install a custom ROM immedaitely? its been so long that i unlocked my phone and installed clockworkmod, I forgot what the steps were when I installed a ROM on my friend's stock Nexus. I ran into a few hiccups, but wanted to find out the most efficient way. Here's what I did.
    1. unlock bootloader.
    2. booted up phone, logged in with google account.
    3. installed rom manager, installed clockworkmod.
    4. installed root explorer and deleted the "recovery-from.boot.p" file cause i know i will restart a lot to install the ROM, Kernal, and new radio update.
    anyhow, after i unlocked the bootloader, i thought there was a direct way to install the ROM immediately. I thought i was able to push clockworkmod using some ADB commands in the past, but couldn't figure it out, so then i did it the long way above! anyone know of a more streamlined method?
  5. #280
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by trmoney24 View Post
    I would do it the same way you did. Don't try squeezing too many things in at once. The phone needs to reboot and time to settle in between flashes. You would also want to fully reboot after unlocking and rooting to make sure everything is working correctly before moving on to making a nandroid backup of the stock ROM. Once everything is working smoothly... then start flashing custom ROMs.
    trmoney24 likes this.
  6. #281
    trmoney24's Avatar
    Posts
    Global Posts
    423 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AXIOM 2.4
    thanks cyber! i figured you would know what the best steps are.
  7. #282
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No problem... it is possible the way you mentioned but I would boot up the phone first to make sure everything was working.
  8. #283
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by rgray331975 View Post
    Link for super boot not working. Anybody want to send it to me via db
    Here you go... new link for the superboot.. I'll update the OP with the new link in a little bit but for now..
    Here: r3-galaxynexus-superboot.zip
    davidnc likes this.
  9. #284
    rgray331975's Avatar
    Posts
    Global Posts
    336 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks buddy finally got drivers to work on his PC. Time to root
  10. #285
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    [NOTE]OP updated with new working link for superboot[/NOTE]
    zero neck likes this.
  11. #286
    rgray's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Fyi found out my USB was 3.0 went to 2.0 and had no prob
  12. #287
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by rgray View Post
    Okay.. thanks for the info. Yea, I've read about a few people who did that and had success with it. I'll add it to the Troubleshooting section of the guide. Thanks.
  13. #288
    4yanx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've tried four times on MAC and each time it refuses to restart from the unlocked google screen. Terminals tells of root success using the ./fastboot boot boot.superboot.img command but ZERO luck finishing after that. Will try on PC later.
  14. #289
    ManBearPig618's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Jelly Bean
    Just unlocked/rooted...everything seemed to go successfully. It's now restoring my apps from market, but everything is downloading extremely slowly. Browser seems to work fine. Could I have messed something up?
    Edit: Finally got through the first app it was downloading (Where's My Water...btw, badass game) and now it seems to be going more quickly. WMW? was a wifi only DL...I don't know if that has anything to do with it.
    Edit 2: And now it's going slow again. When I did the unlock/root, I didn't have the driver file downloaded all the way (although when it did download I opened it and it said drivers were already installed or something similar) - could this be a cause? Or if the correct Samsung drivers had not been present, would the whole process have failed entirely?
    Sorry about the questions....first time rooter.
  15. #290
    BayRican's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CodeName 1.3.3
    just unlocked the bootloader and rooted my G-Nex thanks to this awesome step by step guide. Great Work. Thank You now looking forward to some great roms to try out.
  16. #291
    Castor_troyy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unlocked fine, however when I go to click install-superboot-windows, a command prompt opens, and says downloading boot.img... and just hangs there.
    I also see a blue prompt at the bottom of the phone "fastboot status - download 00467800"
    something going wrong?
    **edit: I seem to have corrected it... just scrolled and hit restart bootloader, then double-clicked install-superboot-windows again, and boom... Google unlock screen, we'll see where it goes...
    edit#2: All is fine, unlocked, rooted, nandroid made... now what to choose..
  17. #292
    goldkear's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock+
    Sorry if this has been covered already, but i have an issue with superuser permissions. I followed these instructions to the letter, but when an app tries to ask for superuser permissions, nothing happens, and the app assumes it is getting denied. Suggestions?
  18. #293
    xeroslash's Avatar
    Posts
    Global Posts
    220 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bought it yesterday; rooted/unlocked today
    Gotta love that Android community.
  19. #294
    dlshaw73's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OMG... I was freaking out, I followed this guide to root my Verizon Galaxy Nexus & it was sooo easy I recommend this to any one who isnt very computer literate. I followed it word for word & had success. Yay finally rooted. Thank you so much.
  20. #295
    DaEXfactoR's Avatar
    Posts
    Global Posts
    322 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nexus 4, Nexus 7
    I just listened to last night's podcast. Someone emailed a question about unlocking the bootloader. The general consensus of the guys was to "UNLOCK THE BOOTLOADER!!!!". My question is, why unlock the bootloader if you are not gonna root? What is the benefit?
  21. #296
    guerreiro's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Guys!!!
    Need help! I have been on this for 3 days already lol. I have tried everything but I still got WAITING FOR DEVICE message when I put a command prompt in!
  22. #297
    eric3316's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Deleted
  23. #298
    GetOnMahLevel's Avatar
    Posts
    Global Posts
    166 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by DaEXfactoR View Post
    because when you find out how awesome this phone is.. and end up wanting to root it.. then you wouldn't have lost all of your pictures and media that's on your phone by unlocking the bootloader later on down the road..
  24. #299
    ENG618's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, this guide was super helpful
  25. #300
    daveferraiuolo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    how come my hotspot still wants me to subscribe ?? i thought you get it free when you root the phone...
