Page 2 of 16 FirstFirst 12345 ... LastLast
Results 26 to 50 of 398
Like Tree48Likes
  1. #26
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,544 Global Posts
    Carrier
    NOS M7 Sense 5.0
    Default Re: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexu
    Not sure yet, wish I had recovery installed to be able to wipe data that would have worked (maybe). Has to be a work around some where.
    here is what i'm trying, I'll let you know if it works
    Originally Posted by MBerlowitz5181 View Post
    I just ran a system wipe/ recovery using the bootloader menu... back up and running.
    All i did was get back into bootloader by holding both VOL up and VOL down then power. once in, i went used vol down to scroll to recover, and then used power to accept. after it ran (5 minutes) it booted fine!
  2. #27
    Upstreammiami's Avatar
    Posts
    Global Posts
    2,199 Global Posts
    Carrier
    JB
    Quote Originally Posted by mclarryjr View Post
    i think you have to push the image file in ADB
  3. #28
    are you kidding me? did we soft brick our phones? that sux what now? cyber going to put up some instructions?
  4. #29
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Actually... the whole phone gets wiped. Including whats considered the sd card.... at least for me it did. Good thing I only had a few test pictures that i had taken.
    Can any one else confirm that the entire phone was wiped.... including storage?
  5. #30
    JkdJedi's Avatar
    Android Enthusiast
    Posts
    Carrier
    SKAnkCM10/Milestone6
    Default
    Quote Originally Posted by Cyber Warrior View Post
    That sounds right to me, android central s last podcast mentioned to unlock your bootloader right away when you get your nexus for that very reason.
    Sent from my DROIDX using Tapatalk
    Cyber Warrior likes this.
  6. #31
    10001110101's Avatar
    Posts
    Global Posts
    397 Global Posts
    Carrier
    There will be many...
    Never messed with ADB until today. Easy as pie. Unlocked and Rooted!!
  7. #32
    kichard's Avatar
    Posts
    Carrier
    KANG cm9/Franco
    Mine was sitting at the google screen for a serious 15 minutes. I pulled the battery, booted up just fine and super user is working correctly. Installed Rom Manager and flashed Clockwork. Idk why you guys are getting boot loops. Maybe I got lucky?? Idk 15 minutes should be more than enough time to load the system images back up. To fix the soft boot wouldn't you just go to the stock recovery and delete data/factory reset?? I mean that's what I would do...
    18TGTI04 likes this.
  8. #33
    ok so i've got a android guy on his back with a red triangle coming out of his stomach did i brick my phone?
  9. #34
    Posts
    Global Posts
    2,199 Global Posts
    Carrier
    JB
    i get bootloop at google screen
  10. #35
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,544 Global Posts
    Carrier
    NOS M7 Sense 5.0
    Quote Originally Posted by Upstreammiami View Post
    Same here and can't find a solution yet but there has to be a way.
  11. #36
    Posts
    Global Posts
    2,199 Global Posts
    Carrier
    JB
    im setting up adb (not recognizing the phone) to restore image ill let you know
    mclarryjr likes this.
  12. #37
    well i'm between google and the spash screen in between keeps saying android upgrading but its been doing it for over a half hour now, sure hope i didnt do anything to the phone just keeps looping between those two screens
  13. #38
    NewAge's Avatar
    Posts
    Global Posts
    1,108 Global Posts
    Carrier
    Various
    Quote Originally Posted by panitsos View Post
    Nope. Pull the battery and turn back on. With root explorer goto /system and rename the file "recovery-from-boot.p", put a 1 in front or .bak. Then with ROM manager reflash CWM and you should be good to go. Boot into CWM.
  14. #39
    kcrandall758's Avatar
    Posts
    Carrier
    MIUI 1.9.23, stock
    alrighty then...I'll make sure to do that - thanks!
    Quote Originally Posted by Terrigno View Post
    For now. Yes. Once its done. Its done lol
  15. #40
    Quote Originally Posted by NewAge View Post
    how can i get to the root explorer if the phone keeps looping? and where would the root explorer be? sorry i'm not too good with tech talk
  16. #41
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,544 Global Posts
    Carrier
    NOS M7 Sense 5.0
    root explorer is an Android application and if your in a bootloop like myself you won't be able to use it. I'm wait to see if upstream is able to push the stock file which should get us out this loop.
    panitsos likes this.
  17. #42
    ok ty i'll keep refreshing this page for any new good news lol
  18. #43
    Thankx! Worked like a charm
  19. #44
    ok guys this is what i did and it worked!! i went back to recovery and wiped data and cache, rebooted the phone and its fine now
  20. #45
    Trantzz's Avatar
    Posts
    Global Posts
    48 Global Posts
    And for a question of my own. If i used this method to unlock the bootloader only, can I just skip to step 14 to root the phone or do I need to use another method to get root.
    Was this answered? I have the bootloader unlocked but not rooted yet?
  21. #46
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,544 Global Posts
    Carrier
    NOS M7 Sense 5.0
    When I go into recovery I don't have any options to wipe or any other options
  22. #47
    NewAge's Avatar
    Posts
    Global Posts
    1,108 Global Posts
    Carrier
    Various
    If you are brave try this:
    From the command prompt pointing to the folder with fastboot.exe, adb.exe and stock images:
    Exact commands:
    adb reboot bootloader
    Gnex will then reboot into bootloader screen
    fastboot flash boot boot.img
    fastboot flash system system.img
    fastboot flash recovery recovery.img
    fastboot flash userdata userdata.img
    fastboot erase cache
    fastboot oem lock
    Use volume rocker to select ok and then Gnex will reboot.
    You are now stock, locked and unrooted.
    Kanged from Steady Hawkin.
    The four files (boot, system, recovery, userdata) are located in the image-mysid-icl53f.zip after downloading from Google. Unzip them and place in folder that fastboot.exe is located in.
    It also contaings a "flash-all.sh" which will allow you to flash them all with one command.
    Command is in this thread as well as link to stock images: http://forums.androidcentral.com/ver...axy-nexus.html
    mclarryjr and DroidRat like this.
  23. #48
    its very easy guys if its done the way i did it, i'm just trying to remember how i went to recovery and was able to pull up the wipe data screen
  24. #49
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,544 Global Posts
    Carrier
    NOS M7 Sense 5.0
    Here is how I fixed my loop - I just locked the bootloader up and then followed the guide again and without pulling the battery this time it worked. Miami let me know if your still having issues.
  25. #50
    So first install the samsung drivers,then install the usb drivers too .
    Then I make sure there are no errors in device manager with phone hook up to computer with USB ticked on phone.So it looks like the picture in the link (samsung drivers first link in OP)
    After that is all checked out download superboot and follow the pictures and instructions til completed.Steps 1-15. I think I m correct on all that ,lol
    I have 2 question more
    I already did the update yesterday so I am on Androd version 4.0.2 so has anyone use this method while on 4.0.2? This one of my biggest concerns Im not sure of.
    Also I may wait and see how everyone is getting out of the bootloop some are having ,I see what some did to get out of the bootloop ,but also see others dont have the same options to use (ex:wiped data and cache)
    edit: ok I see some more posts since I started tying about bootloop question have been posted
