Roms and drop box question.
shugmeat
22
If I go through root explorer, going into /sdcard/clockwork mod/backup/"my file", can I send this "my file" to dropbox and keep it there (as a copy of course). I have my just-rooted-first-backup and want to keep it safe in case of any from problems. Can I do this with titanium backup also? Thanks in advance.
Sent from my GNizzle using Tapatizzle
2defmouze
3,945
1,552
Yes. The backup is actually a whole folder. You can export them at your will. Good idea to keep some key ones on your computer, change the name to whatever you want so you remember what they were.
w8wca
