Page 1 of 4 1234 LastLast
Results 1 to 25 of 83
Like Tree7Likes
    mikestorm's Avatar
    Posts
    Global Posts
    1,004 Global Posts
    Carrier
    Cyanogrnmod 10.2
    Default Anyone using NFC tags with their Galaxy Nexus?
    I think in the next week or so I'm going to buy a handful of NFC tags and start coming up with HOME, CAR, and WORK profiles for my phone.
    Here's what I've been considering
    HOME:
    Wifi on, gps off, bluetooth off, ringer max volume
    CAR:
    wifi off, gps on, bluetooth on, 4g off (not sure if this is possible)
    WORK:
    wifi off, gps off, bluetooth off, ringer low volume, 4g off (not sure if this is possible)
    Anyone with experience using NFC tags have any other suggestions and/or feedback of how well it works with the phone?
  2. #2
    Default Re: Anyone using NFC stickers with their Galaxy Nexus?
    I remember reading about someone who is deving a app to work with NFC stickers. I cant remember where if it was on this board or XDA.
    I love the idea.... is the app available to use? How does it work with the stickers? Where can I get it?
  3. #3
    Found the app!
    https://market.android.com/details?i...actionlauncher
    I think I am going to try it!
    Where is the cheapest place to buy?
    overfloater likes this.
  4. #4
    TWISM's Avatar
    Posts
    Global Posts
    520 Global Posts
    Carrier
    Jelly 'Beans', Stock
    Default
    I am going to checkout www.tagstand.com
    Unless anyone has any other positive feedback on a place they got tags from.
    mikestorm's Avatar
    Posts
    Global Posts
    1,004 Global Posts
    Carrier
    Cyanogrnmod 10.2
    Quote Originally Posted by TWISM View Post
    I am going to checkout tagstand - Buy NFC tags, labels, and stickers here.
    That's where I plan on getting my tags. I've heard that name thrown around a bit.
    There are different types of tags, which can hold different amounts of data. I'll need to do more research so I don't inadvertently buy the wrong type.
  6. #6
    Default Re: Anyone using NFC tags with their Galaxy Nexus?
    With all the fuss over Google Wallet on the GN, I was just wondering if anyone had looked into other possibilities for NFC. A quick Google search turned up nothing except this thread, which I then realized was posted today! Proof that I should always check AC first.
    Appreciate the links. I'm not sure how much practical use I'll really have for the tags right now but... it's tinkering ... it's just cool ... so I can't resist.
  7. #7
    stormed's Avatar
    Posts
    Global Posts
    75 Global Posts
    I don't really know much about NFC, but in order for it to work, don't you have to tap the device on the tag physically to trigger the tag event? I like the idea from the OP about having tags set your phone's profile when you're at certain places...but I would find it kind of annoying if I have to tap the phone on the tag when I got home. OF course, if that's not a requirement, then that would be a great convenience feature.
  8. Thread Author  Thread Author    #8
    mikestorm's Avatar
    Posts
    Global Posts
    1,004 Global Posts
    Carrier
    Cyanogrnmod 10.2
    qdroid, you're right. You pretty much have to tap/hover over the tag to trigger the alternate profile. That said, for CAR or WORK, it's not a big deal. For CAR, put the tag near your car-dock or center console. For WORK, put the tag near your landline on your desk or wherever you normally charge your phone at work.
    Hell, you could even have room specific tags where the bedroom tag (next to nightstand) mutes the phone so it doesn't wake you in the middle of the night.
    To your point, the one tag that could be kind of a pain is the generic HOME tag. That said, the way I look at it:
    • To maximize battery life, it's always a good idea to disable features we're not using
    • I'm not very good at that. I always forget to enable BT when I get in my car or turn it off when I get home. Tags are a redundancy to help me remember, nothing more.
    • Tapping a tag is easier than manually turning on/off/tweaking each of the settings manually
    • If you forget to tap the tag when you come home. No harm no foul, just manually change the settings from where you're sitting
    • Cool factor should not be ignored
  9. #9
    jackrv's Avatar
    Posts
    Carrier
    Axi0m Crossbreed Mono B1
    Default
    This is a very interesting idea! Please let us know how it works!
  10. #10
    Make sure the tags are pre-formatted for NDEF.
    I see a bunch of "applications" to use these tags!
  11. #11
    that sounds like an awesome idea. can you link to instructions on how to setup the commands for the profiles and such? all i have seen online are options similar to QR codes: text, links, facebook, etc.
    thanks!
  12. #12
    CBMC's Avatar
    Posts
    Carrier
    CM7
    Default
    Quote Originally Posted by kilofox View Post
    If you are on 4.0.3 you won't have to worry about being pre formatted. The bug was fixed in 4.0.3. If you are on 4.0.2 then get NDEF formatted tags. (which tagstand does for .20 per tag)
    kilofoxtrot likes this.
  13. #13
    Cool idea, but I already use Locale for most of this. Doesn't really work for the car, but hopefully I can get a car dock with the pins to do that.
  14. #14
    How is Locale for battery life? I had it on the OG but got rid of it a long time ago because of battery drain.
  15. #15
    Quote Originally Posted by ScooberJake View Post
    I found Locale to be reliable about 75% of the time.... that isnt enough in my book.
  16. #16
    Quote Originally Posted by andrew0812 View Post
    True, Locale is not 100% accurate. It's more like 95-98% for me (for location), but it will obviously depend on your individual situation. And the battery life was pretty bad when I first got it (also on my OG), but both battery life and reliability have increased with updates. I don't feel like the battery drain is limiting anymore. It's my favorite app, couldn't be without it. It's the main reason I didn't strongly consider a Windows Phone 7 device. Locale is Android only.
  17. #17
    ZRod's Avatar
    Posts
    btw I use NFC Task Launcher. Does everything ya'll are mentioning and also can launch Tasker actions. Bought my tags from tagsfordroid.com. 20 for $25. They cost slightly more but are a nice plastic with a sticky back and Andy on the front. Worth every penny and you get 768 bytes worth of memory which is much more then you will ever need. If you create a "Profile tag" through NFCTL all your actions are stored on your phone and only 27 bytes is used on the tag if you plan on getting smaller size tags.
    I even have a tag next to my stereo that I just tap and bluetooth turns on and connects to it and starts playing my music from PowerAmp (which I also have the tag launch). Oh and I have mine set to play the Sonic game sound when you get a life so I feel like I am accomplishing something =D
    Have one for home, by my bed, stereo, and school so far. I bought 20 just because.
    Also, you don't have to pay extra to have them format the tags. I just used a Galaxy S at the Sprint store for my Galaxy Nexus. =P
    Only downside is that every now and then the NFC doesn't want to seem to detect the chip and I have to put the phone to sleep then wake it up and usually that fixes it. Then again I have 109 apps on my phone and my 7 screens super customized with widgets and folders and apps so my phone is usually bogged down and has to reload the homescreen 9/10 times. That is my only giff with these phones, can't find anything to yell at my phone "HEY! DON'T YOU CLOSE THAT APP/PROCESS OR ELSE"
    mikestorm likes this.
  18. #18
    bakerbert's Avatar
    Posts
    Global Posts
    452 Global Posts
    Carrier
    JellyBeans
    This is slick!!!
    There could be a ton of uses for this.
    Besides the cool personal uses, business could use it for people to:
    Bookmark website
    Facebook, twitter, Google plus likes/follow
    4 square check in
    WiFi access info
    Just tap your phone here and your customers/patrons instantly have all of your info.
    There are a ton of possibilities with this.
  19. #19
    Quote Originally Posted by bakerbert View Post
    This is slick!!!
    <snip>
    Absolutely. NFC will start appearing in marketing campaigns soon enough -- on movie posters, in-store displays, stands at tradeshows, etc. -- the same way QR has attempted to elbow its way into marketing.
    QR has kinda failed there, IMO. Partly because marketers haven't come up with anything clever to do with it besides directing you to the brand/product website (which usually has a simple URL anyway). And partly because it's a pain in the *** to unlock the phone, find and launch your rarely-used QR recognition app (assuming you've already thought ahead and installed one), mess around with angle and distance trying to get the whole QR code in the camera frame for a good scan, etc.
    In comparison, NFC is a "frictionless" consumer experience: it requires almost no effort, literally just tap your phone against the tag, so there's liable to be far less resistance to adoption. People are far more likely to try tapping their phone against a poster than waste time taking awkward photos of QR codes.
    Of course, NFC is still stuck in the catch-22 phase of adoption because of its additional hardware requirement: few phones have NFC because there are currently few practical applications... and there are few practical applications because there are too few phones with NFC! Hopefully the high profile topic of NFC payment options, and the big players behind it like Google and ISIS (i.e. VZW, AT&T, T-Mob), will give manufacturers more incentive to include NFC in devices so we can break out of the chicken/egg stalemate!
  20. #20
    Why not use a location based app instead?
  21. #21
    Quote Originally Posted by sccpmusc26 View Post
    Usually, Locale being an example, you have to buy plugins to make the app even remotely useful. And I have found they dont always work.
    davidsnoodles likes this.
  22. #22
    Default
    Just ordered a kit from the website listed at the start of the thread I'll play with them let you guys know how it works and might try to sell a few if anyone is interested. But I'll keep you guys updated.
    Sent from my GalaxyNexus using Tapatalk
  23. Thread Author  Thread Author    #23
    mikestorm's Avatar
    Posts
    Global Posts
    1,004 Global Posts
    Carrier
    Cyanogrnmod 10.2
    Scouring the web for other uses and found one action where the use of NFC tags has an advantage: checking in via foursquare, Facebook Places and Google Places.
    Just place a conspicuous tag near the entrance of your business. Customers touch phone to tag as they walk in. Bingo: You've just checked in to the location based service of your choice with a tap (or all of them simultaneously if you use multiple).
  24. #24
    newdroidnewb's Avatar
    Posts
    Carrier
    Axiom/Franko's
    I bought some NFC tags from tagstand . They are very inexpensive and they work as advertised. I also DLed the NFC Task Launcher app from the market. There were others available for free, which I did not try, but this one seemed like the best one for me. It works great and has lots of uses.
    Quote Originally Posted by mikestorm View Post
    To add to that good idea, you can also set up a tag to automatically check you in at your current location. So you could just place a tag somewhere is your car and tap it on your way out of the car to check it. I'm not a checker inner myself, so I haven't and won't be using it this way, but seems like a great way to check it for those that do.
    Main thing I want to bring to everyone's attention though, is that the tags have a memory limit. I did not pay attention to this when ordering and I happen to order only ones that had a 48 byte limit of data.
    A typical "task" that I tried write to the tag is around 60 bytes. I, therefore, couldn't use the tags I got exactly like I wanted to. I was able to write smaller tasks to them and they work fine.
    They were cheap enough that it's not that big of a deal, I'm just out a few dollars and a few weeks.
    All the different tags are very similarly priced, so just make sure you get the ones that work for you.
  25. #25
    Default
    What app did you use on your computer I noticed that the programmer just comes with drivers.
