07-21-2013 02:20 PM
1,477 ... 910111213 ...
tools
  1. sw33tooth's Avatar
    anyone know why I keep getting bootloop when i install 25?
    02-23-2012 01:59 AM
  2. davey11's Avatar
    You have to give more details...how did you install? Did you wipe? Check md5? Any other pertinent info?
    02-23-2012 02:08 AM
  3. sw33tooth's Avatar
    intalled off of cw yes i wiped and i checked md5
    02-23-2012 02:30 AM
  4. davey11's Avatar
    Go back into cwm, under advanced, wipe dalvik, then wipe data/factory reset then flash rom again and flash gapps and it *should* boot.
    02-23-2012 02:41 AM
  5. NotJustAPhone's Avatar
    When I first saw the vid teaser on wiki for the nav bar hide mod, I was whoa gimme somadat. Now in actual use, BLEH. You kinda get caught up in all the hype of an upcoming build, and those guys at wiki can whip up a frenzy.
    Just gotta tell yourself to calm down I guess.
    Sent from my Galaxy Nexus using Xparent Blue Tapatalk
    Same here. Was really looking forward to the option to hide the navigation bar, but after trying it out I haven't used it. I do like the new option to replace the signal bars with a dBm value. Unfortunately, it doesn't show the LTE signal properly but I expect that will be fixed soon enough.
    I tell myself that I will wait until the next milestone but even I don't believe that. As soon as the next build drops, I'll be flashing it.
    Sent using Tapatalk
    02-23-2012 09:26 AM
  6. davidnc's Avatar
    Anyone on AOKP update to the new version of Nova Launcher yet ?
    It's out of beta now also in the market .
    I just update to the Black Ice version of AOKP havent update my Nova Launcher yet
    02-23-2012 04:37 PM
  7. zero neck's Avatar
    yeah i updated and bought prime for 4 bucks. only difference are gestures. not really worth four dollars but i figured i'd support the guy for the launcher that kills stock.
    nice thing about gestures tho - i have swipe up set to voice commands. no more looking for little mic button.
    davidnc and NotJustAPhone like this.
    02-23-2012 04:45 PM
  8. davidnc's Avatar
    yup i would have to add funds to my pre paid card before I bought .l only have 65 cents on it currently ha
    sent from my Htc Incredible
    02-23-2012 05:01 PM
  9. zero neck's Avatar
    ah true my market is set up to a credit card.
    the more i think about it, prime is worth it for me, bc i bet there will be more features eventually, although i have no evidence of this of course. anyway, the gestures are turning out to be pretty useful.
    02-23-2012 05:06 PM
  10. dmmarck's Avatar
    lol just had a SOD. Was downloading 1.0. Have you guys had success? I'm going to wait until I'm home and plugged in before downloading.
    02-23-2012 05:27 PM
  11. zero neck's Avatar
    when i downloaded the prime key it took about 4 minutes to register that i had paid for - i hit the button to try to get the activation code like a thousand times before it worked.
    in the end, i didnt even have to use the code, i guess the payment wwent thru and i had prime.
    not sure what SOD is tho - haha
    02-23-2012 06:49 PM
  12. dmmarck's Avatar
    Sleep/screen of Death. Won't turn on without batt pull.
    Prolly kernel related though.
    zero neck likes this.
    02-23-2012 07:02 PM
  13. Cyber Warrior's Avatar
    just went into the Nova Settings... did a check for updates.. it said 1.0 is available and now in the market. I hit update... instead of taking me to the market it asked if I would like to install the apk... said yes and I now have 1.0 on the phone.. wasn't charged anything.. it just installed right over beta 14
    Edit... never mind.. its says I have 1.0 but I don't have the prime version. I tried going to gestures and it brought up the pop up to enter the activation key.
    02-23-2012 07:16 PM
  14. dmmarck's Avatar
    Yeah I just updated to 1.0. Score!
    02-23-2012 07:23 PM
  15. davidnc's Avatar
    I updated nova but will hold off purchasing til friday.
    02-23-2012 07:46 PM
  16. dmmarck's Avatar
    I'm waiting for Prime until I see what CM9 does
    02-23-2012 07:47 PM
  17. NotJustAPhone's Avatar
    Nice use of gestures. May get the Prime version for that feature.
    Sent using Tapatalk
    02-23-2012 08:02 PM
  18. zero neck's Avatar
    oh true.
    the gesture for voice commands is already really helpful. i have my second and third docks (swipe dock either direction) with just voice command activation, to make it alittle easier to get to, but this far outstrips that method. and less clutter which is nice.
    02-23-2012 09:12 PM
  19. SuperChargedJ's Avatar
    AOKP + Nova Prime =
    02-24-2012 06:32 PM
  20. NotJustAPhone's Avatar
    Have you guys seen Roman's interview on Droid Life? For those who may not know, Roman is the developer behind AOKP. Good stuff.
    http://www.droid-life.com/2012/02/24...-kang-project/
    02-24-2012 07:15 PM
  21. SuperChargedJ's Avatar
    Have you guys seen Roman's interview on Droid Life? For those who may know, Roman is the developer behind AOKP. Good stuff.
    Definitely a great and entertaining read.
    NotJustAPhone likes this.
    02-24-2012 07:18 PM
  22. goph_man's Avatar
    Can anyone help me by telling me what zip/gapps to download for aokp? I tried to download 1 mirror file but was confused about it and it did not work. Any help would be greatly appreciated!
    02-24-2012 11:16 PM
  23. davey11's Avatar
    Just read it. Great read. What's interesting are the comments below the article, about some thoughts on the cnd rom.
    02-24-2012 11:31 PM
  24. davey11's Avatar
    Can you explain further about "it did not work"? If you used the one on the aokp website should work. Check the md5 also.
    When I flashed b25 I used kejar's 404 gapps package and that worked great.
    02-24-2012 11:37 PM
  25. goph_man's Avatar
    I went on to this website: Build 25 and I downloaded the mirror 1 zip for the cdma galaxy nexus and I also downloaded the gapps at the bottom of the page. When trying to install it however it went into an infinite boot loop. Am I doing something wrong? I just tried installing both through sd card rom first then gapps. Thank you for helping I am still a beginner!
    02-24-2012 11:48 PM
