07-21-2013 02:20 PM
1,477 ... 1718192021 ...
tools
  1. zero neck's Avatar
    What about the FA02 Radios. I Flashed them last. I didnt know if M5 had them.
    Custom roms almost never come with radios included.
    Whatever radio you have will persist unless you change it.
    That also goes for nandroid backups - they don't save your radio versions.
    NotJustAPhone and JkdJedi like this.
    04-29-2012 07:23 PM
  2. Bobaroo's Avatar
    Flashed M5. Very quick and smooth so far. Only think I notice is that my signal strength is way down. Where I usually have full 3G and 4G (NYC) I know I have about three bars 3G and 1-2 of 4G.
    04-30-2012 08:49 AM
  3. tony bag o donuts's Avatar
    +1
    04-30-2012 10:03 AM
  4. dmmarck's Avatar
    My signal has been fine. Immediately flashed franco kernel though. Not sure if faux is paying the AOKP guys, but his kernels are simply outclassed IMHO.
    04-30-2012 12:05 PM
  5. Bobaroo's Avatar
    Where can I download the flashable zip of francos kernel? I've been wanting to try it out, might as well now
    04-30-2012 12:09 PM
  6. dmmarck's Avatar
    If you don't have the app, I would check his threads on XDA and RW. There should be a link there for them. I'm using Milestone 3, which IMO, is the best kernel out there right now.
    04-30-2012 12:14 PM
  7. Bobaroo's Avatar
    My Lair Defense app data was not restored. All my time played while commuting...devastating
    Found it and will look it over, thanks
    dmmarck likes this.
    04-30-2012 01:55 PM
  8. jmiesse134's Avatar
    Thanks for the info. I am still trying to figure out which radio works best.
    So on M5 if I reboot I always get the "Unfortunately maps stopped " Pop up twice.
    Anyone else getting this? EDIT: Reinstalled Maps and problem went away. Maybe had something to do with the backup on titanium
    zero neck likes this.
    04-30-2012 03:02 PM
  9. davey11's Avatar
    updated to IMM76I
    ◦differences between IMM76D and IMM76I are ALL in the Galaxy Nexus kernel
    ◦we updated the Galaxy Nexus kernel to Fauxs 16m kernel by default, which incorporates the fixes from IMM76I
    Above quote is from the milestone 5 release. I don't claim to know anything about IMM76I mumbo but I am just wondering if flashing different kernels would muck up anything.
    Some of you probably have flashed francos so the above may mean absolutely nothing.
    Maybe its romans way of saying please use faux's kernel.
    04-30-2012 03:03 PM
  10. zero neck's Avatar
    updated to IMM76I
    you can use francos, it's just that faux's kernel and m5 has the latest changes from source incorporated.
    everyone else's next kernel release will have them as well, i assume.
    davey11 likes this.
    04-30-2012 03:29 PM
  11. kca2000's Avatar
    I have not had most of the issues you guys describe so far on M5. The signal strength seems to be a bit shaky but It is super fast and smooth. I can say is this Faux Kernel is giving me sick battery life as well. Im at 16 hours standby, 2 hours on screen and 49% remaining. usually i am in the 20's with the same stats on francos kernel. I have some more testing to do, but so far it seems to be working out well.
    04-30-2012 03:31 PM
  12. dmmarck's Avatar
    Franco's latest milestone says it has merged the changes, and when on M5 for the day I was on it it was fantastic.
    04-30-2012 03:36 PM
  13. davey11's Avatar
    Gotta agree with you. The included faux is good battery for sure. Nothing scientific, but seat of the pants.
    04-30-2012 04:05 PM
  14. zero neck's Avatar
    shruggin.
    dunno theyre basically all good?
    even stock kernel is nasty on this phone.
    davey11 likes this.
    04-30-2012 04:18 PM
  15. jmiesse134's Avatar
    Screen off wifi action in M5
    Seems to be staying on when screen is off. I have it set to turn off.
    Can anyone check to see if theirs is shutting off? Im on franco M3 btw
    Nevermind... I guess you have to enable powersaver for it to work. You can enable it but you also have to enable powersaver too My bad
    04-30-2012 05:33 PM
  16. mclarryjr's Avatar
    Flashed M5 this morning and everything seems fine not having any issues with signal or anything else. Still to early on battery life but I'll be sure to keep an eye on it.
    Sent from my Galaxy Nexus using Tapatalk 2 Beta-5
    zero neck and dmmarck like this.
    04-30-2012 05:58 PM
  17. zero neck's Avatar
    ill check later running on fumes now and no charger today
    04-30-2012 06:05 PM
  18. klou's Avatar
    Just installed this, and doesn't seem like the notification led works for text messages using the stock texting app. Anyone know how to fix it?
    04-30-2012 07:50 PM
  19. kca2000's Avatar
    Not sure on this. It works for fine for me, but I'm using light flow. Try downloading that if problems continue.
    04-30-2012 09:44 PM
  20. mclarryjr's Avatar
    Anyone else notice all volumes seem to be much lower then any other build I've tried? Did use volume+ to increase the volume and it seems to be helping.
    05-01-2012 08:37 AM
  21. tony bag o donuts's Avatar
    BT is much lower for me....A LOT lower....and of course the crappy speakerphone.
    05-01-2012 08:43 AM
  22. tony bag o donuts's Avatar
    I noticed with build #34 that I have to hit call end twice to end a call.
    Didn't have this issue with #33. Have it with MS 5 though.
    05-01-2012 08:45 AM
  23. dmmarck's Avatar
    I noticed there was some..."lag"...when hanging up. I know the AXI0M build I'm on is supposed to improve the lag between picking up and the call connecting, but have no idea if it works in the reverse.
    05-01-2012 08:48 AM
  24. tony bag o donuts's Avatar
    Back on Axiom?
    If I didn't always have to setup 3 email accounts I guess I would change daily too lol.
    05-01-2012 09:07 AM
  25. dmmarck's Avatar
    Back on Axiom?
    Yeah. New build was released yesterday; I have to update one of the threads b/c the dev essentially abandoned one project (MORPHR), after abandoning two other projects (Crossbreed/Patient Zero), and is now focusing on two projects (lol) (CMPLX, his own rom; "Kang Station," which is his rom + a package of goodies from AOKP, CM9, etc.).
    I like it a lot. Slew of "little" things that makes my cold, black lawyer heart warm and slightly fuzzy.
    05-01-2012 09:26 AM
