1. Coleus's Avatar
    compared to the free version? $6.58 seems like a lot for an app.
    01-25-2012 07:30 AM
  2. orlanka's Avatar
    I wondered the same, but it really, for me anyway, came down to convenience.
    I am not that technical so I don't do much more than the batch operations of backing up, verifying my backups and restoring apps after loading a new rom. With the pro version I am able to do my restore with basically the one click to kicking off the batch run rather than having to agree to installing each app individually.
    I am sure there are others out there that can answer to the more advanced options
    01-25-2012 08:42 AM
  3. mclarryjr's Avatar
    Not really sure beside that like posted ^^^ you don't have to agree to each app when restoring, to me that feature is worth it if you flash new or updated ROM's a few times a week.
    01-25-2012 08:55 AM
  4. jpprice's Avatar
    I'm not sure if its still this way, but the Pro version lets you freeze system apps and such and the free version does not. I have not used the free version in a long time, but I think this used to be the case.
    01-25-2012 09:14 AM
  5. dzyuba's Avatar
    Also some of the handy features that I have used:
    1. Multiple backups per app
    2. 0-click batch restore
    3. Market Doctor (relink apps to Market)
    4. Sync to/from Dropbox
    01-25-2012 09:22 AM
  6. DreamSTi's Avatar
    The best part for me was when restoring apps you don't have to click install for every app. OMG that was annoying.
    beerhound likes this.
    01-25-2012 09:47 AM
