Page 5 of 7 FirstFirst ... 234567 LastLast
Results 101 to 125 of 154
Like Tree88Likes
  1. #101
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [GUIDE] Don't Panic: The Hitchhiker's Guide to the Galaxy Nex
    here is a screenshot from root checker
  2. Thread Author  Thread Author    #102
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Default
    Go to the Mac method guide. Download the 4.0.4 superuser. Zero neck posted it. Flash it in recovery.
    Sent from Oliver, Destroyer of Worlds & Connoisseur of Bean-Shaped Confections
  3. #103
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok I know I sound like a maroon (this is all very new) how do I go about flashing the zip?
  4. Thread Author  Thread Author    #104
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Default
    Quote Originally Posted by reeper55 View Post
    Download it, place on phone, reboot into clockwork recovery, install zip, find that zip on your phone, install, reboot system :-)
    zero neck and 2defmouze like this.
  5. #105
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't have clockwork recovery remember, I am unable to flash it.
  6. Thread Author  Thread Author    #106
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    You're going to need to fastboot it. If I had power I'd be able to help you, but unfortunately I don't so i'm like the Lawrence of Arabia of the DC area right now...constantly moving to find the juice!
    zero neck likes this.
  7. #107
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    You need to DL cwm touch for toro I think iTS version 5.5.04 or something.
    then you put that in the adb folder that contains fast boot .exe
    Put the su zip on your SD card and turn USB debugging on.
    Connect tocpu with USB. Then boot phone into boot loader mode.
    Next CD to your adb folder with terminal commands.
    Then enter this command:
    ./fastboot boot nameofrecovery.img
    That should work let me know if you need more help
    I'm not home but I will be around five if you need clearer instructions.BTW that will boot cwm temp on your phone then you install the su zip in cwm.
    2defmouze likes this.
  8. #108
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dmmarck View Post
    That would just be like the procedure to do the unlock right?
    If so I think I can do it but i just dont know the "file name" to use.
  9. Thread Author  Thread Author    #109
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Are you familiar with fastboot?
    If so...go to clockworkmod.com (or whatever the site is; google it) and download the touch recovery for our Nexus (toro). It is 5.8.0.2.
    Then, get to the bootloader (all volume + power when the phone is off) and cd to the directory the file is in and then
    "fastboot flash recovery recoveryname.img"
    For Ubuntu, it's simply cd'ing to the folder (like Downloads) and "sudo fastboot flash recovery recoveryname.img"
  10. #110
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Guys I am sorry but i am just not familiar enough with this sort of thing to follow what you are asking me to do.
    I believe I am going to need a private lesson and be walked through the process.
  11. Thread Author  Thread Author    #111
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Default
    You may have to wait until I get power. My apologies. :-)
    If someone else wants to, please be my guest!
  12. #112
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you would be willing, I would be truly grateful. No rush, I will be out this evening anyhow. GOOD LUCK getting that power back. I went 3 days without it in October when we got that huge snowstorm in Massachusetts.
  13. Thread Author  Thread Author    #113
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    I'm at my school (former) right now. If you want, I can walk you through the steps on a Mac. No idea how to fastboot crap on a Windows machine.
    I prefer doing it by Gchat. Do you have that?
  14. #114
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I only have a windows PC, no Mac here.
  15. Thread Author  Thread Author    #115
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    That is unfortunate! My apologies .
  16. #116
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Let me know if you still need help, I'm not 100 percent on PC instructions but I can help you.
  17. Thread Author  Thread Author    #117
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Oh, I forgot about this option--but you can use Wug's to fastboot stuff.
    reeper55 and zero neck like this.
  18. #118
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks a bunch. I'll give it a try in a bit. Trying to my baby girl down for a nap.
    dmmarck likes this.
  19. Thread Author  Thread Author    #119
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Just make sure all of the drivers are installed and that you follow his instructions, but he should be able to make you right in a matter of seconds lol
  20. #120
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Smile Re: [GUIDE] Don't Panic: The Hitchhiker's Guide to the Galaxy Nex
    You were right!!!!! I am now rooted. Now i need to figure out how to get JB on there.
    Thanks for the guidance sir!!
  21. Thread Author  Thread Author    #121
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Did you permanently flash CWM?
  22. #122
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I did.
  23. Thread Author  Thread Author    #123
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    I did.
    Then go read my Jelly Bean guide, particularly the first post.
    Read it twice too.
  24. #124
    reeper55's Avatar
    Posts
    Global Posts
    190 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yeah I skimmed it but paid close attention to where you scare away noobs like me! LOL
    I am feeling a tad intimidated
    dmmarck likes this.
  25. Thread Author  Thread Author    #125
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Just gotta be careful, really careful. That's all .
