Page 16 of 17 FirstFirst ... 1314151617 LastLast
Results 376 to 400 of 409
Like Tree183Likes
  1. Thread Author  Thread Author    #376
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Default Re: [RADIOS][VZW] Galaxy Nexus Radios and Installation Guide
    Quote Originally Posted by garyk66 View Post
    If I'm flashing new radios in recovery mode, do I need to wipe the cache partition and Dalvik cache if I am just flashing different radios? It mentions in CyberWarrior's guide you only need to wipe these if you're only flashing themes,etc. I wasn't sure if flashing new radios required a full wipe, or any wipe for that matter.
    nah you dont need to wipe anything. definitely don't do a full wipe (data) - that will erase your rom.
    you can clear dalvik cache and/or cache partition - won't hurt, but also wont have any effect when flashing a radio. doesnt matter there.
    2defmouze likes this.
  2. #377
    garyk66's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [RADIOS] Galaxy Nexus CDMA Radio Thread
    If I flash new radios using the recovery method, will I still get OTA updates? Also, the fast boot method sounds interesting, but I am concerned about wiping the phone and starting from scratch. I am only doing this because of Bluetooth quality issues since 4.0.4. I now have 4.1.1 and the problem was not corrected.
  3. #378
    2defmouze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Fastbooting the radios is just another way to do (a more proper way, in fact). You won't lose any data either way.
    However, the radios shouldn't have any effect on bluetooth quality, and if your radios don't match your system version than no, you probably won't be able to install an OTA, although you can always flash the old ones easily.
    zero neck likes this.
  4. #379
    lovemachine35's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I hear there is new base band with android 4.2.2. Is this the case and if so when will the new radios be posted at the start of this thread?
    I love all the sticky threads here like this one. Great resource. Keep up the good work.
  5. #380
    Wicket's Avatar
    Posts
    Global Posts
    243 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lovemachine35 View Post
    the new baseband is for the Nexus 4 to disable the hack to use LTE. As for Verizon and a baseband I'm convinced that's why we haven't recieved an update in 4 versions now.. that and they do take a few months to test things.. the radios in the Galaxy Nexus (toro) are rubbish and Verizon knows it and refuse to release an update till they fix what they seem to not be able to fix..
  6. Thread Author  Thread Author    #381
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    afaik we don't have a new baseband/radio for vzw gnex yet. it'll be available when toro is updated to 4.2 i believe.
    if i somehow missed something, tho, post up the link and i'll update the thread. pretty sure it's not available yet, tho
  7. #382
    Xterror's Avatar
    Posts
    Global Posts
    257 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock with XDA Google Now
    Quote Originally Posted by Wicket View Post
    I don't know much about radios, but I hear the VZW Gnex has issues. What does this mean? Is this why my battery dies so fast? Thanks
  8. Thread Author  Thread Author    #383
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Quote Originally Posted by Xterror View Post
    The radio issues are kind of a combined issue - the radio hardware isnt the greatest; and some devices will work better with other versions of the radios (there are several you can experiment with).
    The battery life is generally an issue of regardless of radio, but the radio could be a factor in losing more battery than you should if: due to weak signal, your phone is constantly searching for network or handing off between lte/3g/1x.
    hope that helps
  9. #384
    Xterror's Avatar
    Posts
    Global Posts
    257 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by zero neck View Post
    hope that helps
    I think I get it. I do notice that if I'm on WiFi my battery does a lot better. If I'm in a lte/3g spot where it keep switching the battery drains very quick. I thought bad radio hardware couldn't be fixed, but I guess radio software can make a difference?
    Sent from my Nexus 7 using Tapatalk HD
  10. Thread Author  Thread Author    #385
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    some radios will hand off faster, pick up the signal more consistently, etc - i found the most recent 4.1.1 radios to work best for me.
    wifi definitely uses less juice than the network, especially if you're not searching for wifi or handing off all the time.
    the other thing i used to do was turn off lte. i only used 3g, and that will save ya alot of battery. even still tho, the battery life on gnex isnt terrific.
  11. #386
    Xterror's Avatar
    Posts
    Global Posts
    257 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I should try this for when I know I'll be out of WiFi for a long time and only turn on lte if I need it. Thanks
  12. Thread Author  Thread Author    #387
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    np, i personally saved a ton of battery that way. i actually never turned lte back on after i turned it off (never needed the speed, i dont download much on the phone, and rarely watch videos on it. that and i stay on wifi when it's available).
    good luck
  13. #388
    jmorosky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOSPA 3.99/ Golden Kernel
    This just showed up in XDA. Galaxy Nexus > [CDMA][Radio] 4.2.2 JDQ39 Radios > XDA
    Already flashed it. Nothing unusual to report. Downtown CLT always has a strong signal.
  14. Thread Author  Thread Author    #389
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Quote Originally Posted by jmorosky View Post
    Dope. I'll update the thread late tonight.
    ohiomoto likes this.
  15. #390
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Slacker.
  16. Thread Author  Thread Author    #391
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Quote Originally Posted by dmmarck View Post
    Slacker.
    ahahaha what's good d.
  17. #392
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Making bread, having no life. Flashing radios in beltway traffic. Nah mean.
  18. Thread Author  Thread Author    #393
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    You guys are gonna have to bear with me - i got an emergency thing to do (won't bore you with the details) for my law journal last night, got home at 3 am, have class all day, have work to do tonight, etc. I'm basically completely F#$%^&*(d.
    I'll get to this asap but i can't promise ya when it will be. But, if you get the new radio files for recovery, you can just follow the directions in the OP using the new files instead of the ones i've mirrored in post 1.
  19. Thread Author  Thread Author    #394
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    sorry sorry sorry sorry im insanely awesome busy these days. iswear i'll update the op.
  20. #395
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    iSwear you better not use that term again...
    2defmouze and zero neck like this.
  21. Thread Author  Thread Author    #396
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    hahahahahahah
  22. Thread Author  Thread Author    #397
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    OP is up to date. iApologize for the delay, iHave been very busy.
  23. #398
    trunks527's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Anyone know if the official update radios differ from the leak?
  24. Thread Author  Thread Author    #399
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Quote Originally Posted by trunks527 View Post
    pretty sure they're the same.
  25. #400
    Afroz Munshi1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi, I have a question for you guys and was hoping you could provide an answer for this. I have a verizon GNEX and got the 4.2 update yesterday. I updated the phone and I got terrible signal on my Phone. So I reverted back to 4.1 and had perfect reception again.
    My question is, can I update my phone to 4.2 and then go back, unlock my bootlooder and "JUST" flash the radios that were in 4.1.....? Is this possible....? I have a MAC and I have been flashing everything through the "Terminal" command...
    so my phone would have 4.2 (verizon) and my Radios would be from 4.1... Possible....?
    Please advise.
