Page 2 of 17 FirstFirst 12345 ... LastLast
Results 26 to 50 of 409
Like Tree183Likes
  1. #26
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Default Re: [RADIOS] Verizon Galaxy Nexus Radios and Guide
    Quote Originally Posted by Android666 View Post
    I must be doing something wrong. Whenever i put my phone into recovery mode it will show the android with chest open and a red triangle with an exclamation point in it. But it will stay like that for a few minutes then just reboot without letting me do anything else. Am I doing something wrong or did I not install something I needed?
    Are you rooted/unlocked?
    zero neck likes this.
  2. Thread Author  Thread Author    #27
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Quote Originally Posted by dmmarck View Post
    either that or you need to reflash recovery every time you want to use it if you are on stock-rooted/unlocked.
  3. #28
    Android666's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok got it to work thanks for the guide.
  4. Thread Author  Thread Author    #29
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Updated post 2 with a couple hybrid radios.
    Working on fastboot instructions/radio .img files for fastboot flashing. Need some time for that tho, with school and everything.
    2defmouze and dmmarck like this.
  5. #30
    axne1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Reply
    sent from a Android device
    I'm always on!
  6. #31
    PsYcHoNeWb's Avatar
    Posts
    Global Posts
    2,143 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Awesome stuff Zero Neck! Just flashed my 4.0.4 radios and went smoothly. I am not sure if this would be something to note but flashing the LTE radio was very quick but the CDMA radio took significantly longer, I would say a full minutes as opposed to LTE which took 10-15 seconds.
  7. Thread Author  Thread Author    #32
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    ^that seems a little long but as long as it shows the change in settings>about phone>radio baseband version, you should be good (it should read FA02 for both cdma and lte on the 4.04 radios).
  8. #33
    2defmouze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Default
    Quote Originally Posted by creccaj1 View Post
    Yes that's standard. I thought it was mentioned in his guide... But if not maybe you'd want to add a note about the CDMA radio taking a minute so ppl don't panic halfway through haha
  9. Thread Author  Thread Author    #34
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    i'll mention it when i have min
    thanks 2def
  10. #35
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Big Red Galaxy Nexus getting 4.0.4 IMM76K?
    You must be on the 4.0.2 radios to flash these. I recommend flashing 4.0.2--REBOOTING--going back into recovery, then flashing the attached file.
    Edit: DT also has a file, with bootloader included.
    http://rombot.droidhive.com/ROMs/tor...BOOTLOADER.zip
    He says ==>
    "FYI, It will Flash the Bootloader, Revert the LTE, Patch the LTE to the New and Flash the CDMA. "
  11. #36
    davey11's Avatar
    Posts
    Global Posts
    2,912 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So where is zero? We need the op updated NAOO. jk
  12. #37
    callofduty4's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    He says ==>
    Thats annoying how you cant just flash it over the leaked version...
  13. #38
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Quote Originally Posted by callofduty4 View Post
    With DT's package you. I actually flashed his package just now OVER the new radios, and all is well. He does good work.
    This is essentially the new version of the "GET READY PACKAGE" he has for his roms. It also includes the 4.0.4 bootloader, while the other one--I believe--does not.
    Therefore, I recommend flashing his package.
  14. Thread Author  Thread Author    #39
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    word. i'll update OP but prolly not till later or tomorrow. (reading)
    or it might be best to get a version wihtout the bootloader so they can just be flashed without the reversion to 402.
    anyway - will flash dt's version and see how it goes.
    get at yall later.
    btw - dmm - and anyone else with dl links for these new radios - have md5?
  15. #40
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Im running AOKP though, not sure how that'd work
  16. #41
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Quote Originally Posted by zero neck View Post
    get at yall later.
    Yeah, DT's version works best for people like us running 4.0.4 across the board. If you do flash back to 4.0.2, I can't recommend rebooting enough. This is the second time I flashed this without rebooting, and it didn't work (counting the leak in Feb that is). Rebooted, reflashed the .4 package, perfect.
    Don't worry about that; it'll flash fine. Flash his file in CWM, go to about phone to check if you have FC## under the basband.
    Also, in case anyone was wondering, you can flash DT's package on top of the package I just linked to, b/c I'm nuts and have to flash everything like an addict.
  17. #42
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So all I have to do is flash his file? and ill have the new radios?
  18. #43
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Yup. New files and new bootloader. You should be fine. If for some reason installation aborts, and you're on the 4.0.2 radios still (EK## under baseband), flash the file I uploaded in the linked thread. I do not believe that contains the new bootloader, however, while DT's does. If that's your thing, do what I did and flash DT's file on top of that.
    That being said, all you need to do--or should need to do--is flash his package lol
  19. #44
    davey11's Avatar
    Posts
    Global Posts
    2,912 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There are md5's for the patch files, but since theory's file is better I think dmm should have that. Right dmm?
    Sometimes I skip checking md5, but on this type of file, you gotta make EXTRA sure of them md5 checksums.
  20. #45
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wait so one more time to clarify
    1) Im running 4.0.4 AOKP
    2) Im running the leaked 4.0.4 radios
    3) It is still okay for me to flash his package
    4)Saying "Flash his package" is pretty funny
    So im good to go?
  21. Thread Author  Thread Author    #46
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Quote Originally Posted by davey11 View Post
    word. HIGHLY RECOMMENDED you check md5's for radios and bootlaoders. Like, always
    That said i'm real busy but i'll try to update op with something by tonight, only dt's package or something. I dont like having people go back to 4.02 bc they might forget or not read the op
    then they
    i'll look for the md5 later on the hive when i'm done drinking 36 beers and reading the entire syllabus of every class ten times.
    davey11 likes this.
  22. Thread Author  Thread Author    #47
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    So im good to go?
    You can flash the DRoidth3ory package dmm linked above - its the one from droidhive
    Check the md5 first if dmm posts it up
    btw - this is the one you can "just flash" http://rombot.droidhive.com/ROMs/tor...BOOTLOADER.zip
    Cyber Warrior likes this.
  23. #48
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    I posted an MD5 for the file I uploaded. For DT's file, let me see if I can find one on his site.
    This is all I got ==> http://www.droidhive.com/forums/inde...-404-official/. He didn't post an MD5. I can try pulling one with an app?
    FWIW, my phone has yet to explode and it has FC##, so all's good with it lol.
  24. #49
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I guess ill wait for the MD5 before I try and flash it
  25. #50
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Don't worry, I'm getting it
    MD5 for DT's package = 251a34fd6bdb59458911315c712f0051
    zero neck, oxymoron and axne1 like this.
