09-18-2013 06:30 PM
409 ... 23456 ...
tools
  1. youngzayiles's Avatar
    Im on it now... Just did my backup and im on to flashing..
    dmmarck and zero neck like this.
    05-02-2012 11:13 AM
  2. davidnc's Avatar
    I flashed the new radio/bootloader this AM too. At work which has always been a lousy area for any smartphones I had (incredible, and dx).
    The new radio's made a little difference will know more when back on my home turf.
    However I can definitely see a lot stronger WiFi's connection then I did yesterday
    zero neck likes this.
    05-02-2012 11:18 AM
  3. NotJustAPhone's Avatar
    3G/LTE handoffs are nearly instantaneous now. In the past, it could take well over a minute to switch. (I'm in an area with good LTE and 3G service but keep data on 3G most of the time.)
    05-02-2012 11:22 AM
  4. MegaSoundwave76's Avatar
    I flashed the FC04/FC05/bootloadee radios on BAMF Paradigm 1.25 and its been super solid for me. 3g/4g hand off has been great and getting around high 60's dbm compared to low 80's with the older radios. I think I found a winner.
    05-02-2012 12:41 PM
  5. steveinil's Avatar
    i flashed the new new radieos my baseband is i515.09 v.f04/i515.fc05
    is that right im thinking thats still the old radieos?
    05-02-2012 01:48 PM
  6. dmmarck's Avatar
    You mean your baseband is ==> i515.09 FC04/FC05?
    if that's the case, you're good to go .
    Old 4.0.4 radios = FA##.
    steveinil and zero neck like this.
    05-02-2012 01:50 PM
  7. zero neck's Avatar
    those are the new ones.
    FC04 / FC05
    you're good
    05-02-2012 01:53 PM
  8. steveinil's Avatar
    yep thats it just cant type lol mine does have a V in there though
    I515.09 V.FC04 and FC05
    05-02-2012 01:53 PM
  9. dmmarck's Avatar
    So does mine ; )
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
    05-02-2012 01:55 PM
  10. youngzayiles's Avatar
    Yo you are the man.... I was looking for a step by step and this is beyond easy to follow.. Think im getting this rooting thing down... Next thing you know ill be building android phones.. Ok, I lied but it sounded good.. lol
    zero neck, dmmarck and davey11 like this.
    05-02-2012 03:07 PM
  11. 2defmouze's Avatar
    You taking orders yet?
    05-02-2012 03:17 PM
  12. youngzayiles's Avatar
    Yeah I have a octa core beast im building in my garage With a rom, kernel and radios to match... LOL! But on a serious note my freaking signal has changed dramatically.. Thank you 6lb 8oz baby Jesus...
    zero neck and 2defmouze like this.
    05-02-2012 03:37 PM
  13. zero neck's Avatar
    I want mine to turn into a submarine shaped like an octopus.
    Thx.
    05-02-2012 04:13 PM
  14. PsYcHoNeWb's Avatar
    Just flashed over Liquid 1.35 with old 4.0.4 radios and worked like a charm. Now running new radios without a hiccup in the process! Thanks for posting again Zero!
    zero neck, 2defmouze and dmmarck like this.
    05-02-2012 04:15 PM
  15. Gherkin Savorus's Avatar
    Thanks Zero. Easy as pie. Up and running with the "new" 4.0.4 radios after flashing directly over the leaked 4.0.4 radios from a while back. Took all of 5 minutes.
    05-02-2012 05:51 PM
  16. Vaffanculo403's Avatar
    nice!
    05-03-2012 11:32 AM
  17. zero neck's Avatar
    updated post 2 with 4.04 "imm76k" radios package without the bootloader.
    sicario666 and davidnc like this.
    05-03-2012 12:10 PM
  18. tacticalfats's Avatar
    Still figgerin' all this out:
    What is the point, risk or benefit of flashing the bootloader inclusive file vs just the radios???
    05-05-2012 09:33 AM
  19. Cyber Warrior's Avatar
    You can't use the stock recovery... you need a custom recovery (CWM/ClockWorkMod Recovery) in order to flash the radios. In order to install CWM Recovery... the phones bootloader needs to be unlocked.
    1) unlock bootloader
    2) install/flash CWM Recovery
    3) install/flash radios
    05-05-2012 09:44 AM
  20. tacticalfats's Avatar
    I'm unlocked/rooted/running AOKP with the leaked 4.0.4 radios (FA versions).
    I'm just befuddled by the new radio files which are available with and without the bootloader packaged in.
    05-05-2012 09:50 AM
  21. zero neck's Avatar
    Currently you don't need the updated boot loader bc the radios will work on the old bootloader, at the same time it won't harm anything to flash it.
    The risk of flashing bad radios or boot loader is messing up your phone, so make sure to check md5 before you flash.
    05-05-2012 09:57 AM
  22. Cyber Warrior's Avatar
    You needed to be on the 4.0.2 radios in order to flash the 4.0.4 radios... some of us were already running a leaked version of the 4.0.4 radios from a month ago and didn't want to have to revert back... potentially losing root.
    DT put together a package that downgrades you back to 4.0.2, flashes the new 4.0.4 bootloader and upgrades the radios to the official 4.0.4 radios... its much easier.
    Info is on page 2.
    05-05-2012 10:00 AM
  23. zero neck's Avatar
    That's correct. That's why a day or two later I added the file with just the radios, for those who don't want the boot foe whatever reason, or already had flashed it, when just the radios were made available with the patch to circumvent rolling back to 4.02 to upgrade.
    05-05-2012 10:07 AM
  24. tacticalfats's Avatar
    So I can just flashed the non-bootloader equipped file and I'm GTG?
    05-05-2012 10:19 AM
  25. zero neck's Avatar
    Yup check md5 and flash in recovery mode
    05-05-2012 10:44 AM
409 ... 23456 ...
