1. SpeedJunkie69's Avatar
    I just rooted my Nexus and was wondering how you guy keep all your stuff backed up? Since you have to factory reset a lot I assume everything gets wiped off the internal storage, so what is the best way to keep that stuff safe?
    06-29-2012 05:52 PM
  2. 2defmouze's Avatar
    SD is not wiped when you wipe data/factory reset from recovery. Everything on it is fine.
    06-29-2012 05:59 PM
