1. Iceman0803's Avatar
    As the title says I'm having problems with rebooting my phone when running JB ROMs. When I reboot my phone, about 50% of the time, it will hang on the Google logo requiring a battery pull (or 2) to boot normally. This happened with the JB GSM port, JellyBelly, and now Bugless Beast. Is anyone else experiencing this or know what's causing it and how to fix it?
    07-19-2012 07:56 PM
  2. dmmarck's Avatar
    Flash the JB Bootloader and have patience .
    Iceman0803 likes this.
    07-19-2012 08:09 PM
  3. Iceman0803's Avatar
    Now I feel like an ***** lol. That didn't even occur to me.
    dmmarck likes this.
    07-19-2012 09:32 PM
  4. scarryman04's Avatar
    I flashed the JB bootloader and my boot times went from a few minutes to under a minute so it def helps
    dmmarck likes this.
    07-20-2012 08:49 AM
  5. dmmarck's Avatar
    I mean is the boot still long? Relatively, sure. But it certainly helps .
    07-20-2012 10:06 AM
  6. Iceman0803's Avatar
    I have no more hangs and boot times seem normal to me.
    07-20-2012 11:00 AM
  7. nofiz's Avatar
    how do you reboot the nexus 7 i'm new to Android.
    07-22-2012 10:40 AM
  8. digitalslacker's Avatar
    Hold the power button down...
    nofiz likes this.
    07-22-2012 10:44 AM
  9. Iceman0803's Avatar
    Looks like I still get hangs every once in a while. Not as often as I did with the old bootloader but it does still happen.
    07-26-2012 07:50 AM
  10. oxymoron's Avatar
    I haven't flashed the jb bootloader yet because I haven't had to. My boot times are the same on jb source ROMs as ICS ROMs... actually a little faster. The ports had longer boot times though.
    I keep an AOKP ICS backup on my SD "just in case". I guess there's a flashable zip of the jb bootloader somewhere, but I don't have it... so in the meantime I'm sticking to the ICS bootloader for "insurance".
    Sucks that some of you guys are having boot problems on jb. If I were, I'd flash it too!
    2defmouze likes this.
    07-26-2012 08:07 AM
  11. Iceman0803's Avatar
    I'm currently running the Bugless Beast JB nightlies, which I think are built from source. So I was surprised that I'm still getting hangs even after flashing the JB boot loader.
    07-26-2012 08:24 AM
  12. oxymoron's Avatar
    Yeah, that sucks dude. If it were me, I'd probably relock then unlock it again to see if it cleared it up. Although, I'm a crackflashing *****. Shhh.
    07-26-2012 08:50 AM
  13. 2defmouze's Avatar
    Lol I deleted any ICS backups weeks ago.. knew I was on JB to stay
    I still see occasional long-boots or hangs but its very rare these days, I guess as oxy said it's possible your phone just needs a good cleaning...
    At least doing that makes you a 'clean' one...?
    oxymoron likes this.
    07-26-2012 08:59 AM
  14. Iceman0803's Avatar
    Yea, once I get home I'll do a clean install. I've been "dirty" flashing all of the nightlies (with the exception of the initial BB flash) because Peter said it was OK to do so in the FAQ on his site.
    07-26-2012 09:09 AM
  15. 2defmouze's Avatar
    Yeah.. most of the time it will be fine but when things start getting weird on your phone and you haven't done a clean wipe in a while you can be pretty confident you need one.
    Remember the devs wipe their phones many times a day working on this stuff, and while they can recommend that its ok to dirty flash from one version of the ROM to the next, they can't know the long term effects of doing it through multiple versions.. they're just trying to make it easier on you. After a number of dirty flashes you can assume you need a clean install sooner or later to clear out all those "ghosts in the machine"
    07-26-2012 09:16 AM
  16. oxymoron's Avatar
    Indeed. It keeps away that "not so fresh" feeling.
    07-26-2012 10:47 AM
