07-12-2014 06:53 AM
177 ... 23456 ...
tools
  1. 2defmouze's Avatar
    Hola.. was out of town and busy last night, but glad you were able to figure everything out
    08-19-2012 10:17 AM
  2. KYHusker's Avatar
    Seriously this is the most important guide to read when I am having a rom flash addiction relapse. tytyty.
    (Saw a vzw ad on TV as I typed this selling gnex for $99 ... really)
    2defmouze likes this.
    08-19-2012 08:27 PM
  3. dmmarck's Avatar
    I can now personally attest to the awesome of this guide.
    On another note, apparently you cannot flash a kernel and ROM in the same session for the Nexus 7. Oi.
    08-21-2012 01:21 PM
  4. jean15paul's Avatar
    AAARRRRGGGGGGGGGGG!!!!!!!
    After trying everything above (deleting that com.keramidas.titaniumbackup folder, deleting the app cache and data, wiping the system cache and dalvik from recovery, and uninstalling TiBu updates) I finally just uninstalled TiBu, and reinstalled it from the market. I tried to make create a backup and I still got the error, "Backup failed: Insufficient free storage space." I have 24.75 GB free, so it can't be that I actually don't have enough free storage space. I don't know if they is relavent, but TiBu shows that I have 26.5 GB free on the main screen.
    Someone please help. I'm thinking of emailing the dev.
    Update: I finally got TiBu working again, but it was a challenge.
    I did all the stuff above (deleting that com.keramidas.titaniumbackup folder, deleting the app cache and data, wiping the system cache and dalvik from recovery, uninstalling TiBu updates, and finally uninstalling TiBu and reinstalling it from the market). And even with a fresh install I was still getting that "insufficient free storage space" error whenever I tried to make a backup.
    So I copied the backup folder to my computer and tried to delete it from my phone. And I got an error in ES File Explorer that the files couldn't be deleted. Then I fired up TiBu and told TiBu to delete all backups. It said that it succeded but the backup files didn't go away, and when I restarted TiBu it found them again. I tried to move the backup files to a different folder on my SD Card, but got denied again. So I just renamed the "TitaniumBackup" folder that they are in.
    SUCCESS!!!!
    Once there was no more "TitaniumBackup" folder. Then Titamium Backup starting working and I was able to make a new backup. I still don't know why it thought I had no free storage space; my best guess is that "TitaniumBackup" folder where the backups are stored got corrupted or something. Anyway, I have a working backup so now it's time to get flashing.
    pmcd1962 likes this.
    08-21-2012 02:11 PM
  5. Canuckfan's Avatar
    So after flashing roms/gapps/TiBu, do you need to wipe cache and delvik right before rebooting the system? I've seen it mentioned in some other guides but I only trust one guide
    08-21-2012 04:38 PM
  6. pmcd1962's Avatar
    Wipe before install.
    08-21-2012 05:02 PM
  7. Canuckfan's Avatar
    Right. But do you need to wipe cache/delvik again before rebooting?
    08-21-2012 05:36 PM
  8. dmmarck's Avatar
    You mean after you flash those 3 things? Doesn't hurt, but it's not really necessary.
    Canuckfan likes this.
    08-21-2012 05:44 PM
  9. Empty Hand's Avatar
    Request for sticky status. (Although this thread never seems to be far from the top...)
    08-22-2012 12:58 PM
  10. jean15paul's Avatar
    Cosign on the sticky
    08-22-2012 05:42 PM
  11. dmmarck's Avatar
    Just want to note that this is my second time using this guide. It's quite exciting!
    09-04-2012 11:14 AM
  12. InclusionInnovates's Avatar
    This is such a great ... just finished using it again ... could you say more regarding this statement:
    "But do NOT restore data to any Google apps, and try to avoid it for any apps which actively sync often or create accounts in your phone setup"
    What are apps that actively sync often or create accounts in your phone setup?
    09-08-2012 06:41 PM
  13. 2defmouze's Avatar
    Glad you're finding it helpful! Apps that come to mind which either sync a lot or create accounts in your settings area would be like Facebook and Dropbox, probably plenty others I can't think of or don't use. Can you get away with it? Maybe sometimes, but it can give you issues, so I suggest just restoring apps like that without data, then log in and set them up. The minute or so it takes is probably better than the headache of restoring bad data
    InclusionInnovates likes this.
    09-08-2012 06:46 PM
  14. mraviator's Avatar
    I'm restoring my apps right now. Thanks for the great write up!
    Is there any setting that will auto install the apps without me having to click install for each and every one?
    09-26-2012 06:01 AM
  15. 2defmouze's Avatar
    Thanks and your welcome! Batch restore, as is used in the guide.. if it's not an option it might require the paid/pro version of TiBu, which is well worth the couple bucks
    09-26-2012 06:18 AM
  16. jean15paul's Avatar
    Yeah Batch restore is a paid only feature.
    Question: your guide says...
    7.Skip the initial device setup screen. This can be done by quickly tapping the top-left, top-right, bottom-right, and bottom-left corners of the screen in that order. Or you can just skip through everything without entering your Google account info.
    8. Launch TiBu and do Batch > Restore missing apps with data. Now here's the important part.. hit Deselect all. Go through the list and manually select the apps you want to restore with data. You can do it safely for MOST user apps: games, utility apps, etc. But do NOT restore data to any Google apps, and try to avoid it for any apps which actively sync often or create accounts in your phone setup. Can you get away with some of these things sometimes? Maybe.. but just don't take the risk. Restoring any bad data you shouldn't could mean you'll have to re-wipe and start all over again. Once you're done selecting, hit the green checkmark to start the restore.
    9. Now run through that last step again... This time after hitting Deselect all, hit App only. Now you can select the apps you are going to restore without data. You can do this for just about anything, including your google apps. Its the same as installing them normally.. TiBu will just do it for you in one quick batch job. Afterwards you can do a Menu > Restore data from XML and restore any the call logs and SMS data we backed up earlier as well.
    10. Reboot. Go to Settings > Accounts > Add your Google account and set up your phone again. You can take it from here
    Is there any problem with doing it this way?
    7. Setup phone/Sign into Google
    8. Allow Play Store to auto restore apps
    9. Open TiBu and restore data for specific apps where you want to restore data
    Basically my question is, is there a problem with letting the Play Store automatically reinstall the apps and only using TiBU to restore data?
    09-27-2012 01:37 PM
  17. 2defmouze's Avatar
    Question you guide says...
    [B]
    Its just a more roundabout, cumbersome way to do it. Letting TiBu handle the restores is faster and you can decide exactly which apps you want reinstalled, rather than having the Play Store automatically do them all (which a lot of the time it isn't even that reliable and randomly forgets some apps). You can certainly do it the way you asked about, but the method I use is much easier if once you get used to it. Haven't let the market restore to my phone in almost a year here, lol
    jean15paul likes this.
    09-27-2012 01:41 PM
  18. mraviator's Avatar
    I actually have the paid version of TiBu. I flashed it using the update.zip method so it would be ready to go on boot up. But I noticed the "get the pro version" button when I started TiBu to load my apps. I briefly wondered if that was because I was not logged into the Google ecosystem and therefore no license check was made? Next time I'll have to pay more attention and see if i can get the batch mode to work.
    09-27-2012 03:02 PM
  19. AppleBonker's Avatar
    Are you sure you created the "update.zip" AFTER entering the pro key? I believe this makes a difference.
    09-27-2012 03:07 PM
  20. mraviator's Avatar
    I think i did. I had the pro version installed for months when i made the zip file.
    09-27-2012 03:11 PM
  21. 2defmouze's Avatar
    The pro key is a separate download, but TiBu backs it up and restores it, and I believe if the update zip is made with it installed you don't even need to worry about it.. So not sure why that happened but give it another go.
    09-27-2012 03:22 PM
  22. Canuckfan's Avatar
    Yah, I had that problem before as well and I'm pretty sure I was logged into Google at the time. Not sure what the issue was but all I did was re-install the Pro Key from the Play Store and that fixed it.
    And as 2defmouze mentioned above, if you create an update.zip you don't even need to install/restore the key. I noticed this the last time I did a clean install.
    09-27-2012 10:14 PM
  23. habanophile's Avatar
    Nice guide mouze. thanks. Excuse me. Mr. Advisor mouze sir.
    Personally I use my backup. I remember cyber warrior mentioning it once when I first rooted my phone. Tibu always looked too confusing for me lol. Not anymore!
    09-28-2012 08:57 AM
  24. mrholzapfel's Avatar
    Is anyone else having trouble restoring back data from XML? I get a force close or an error message 'operation cancelled' after I do a full wipe and new ROM install, when I try to restore SMS, call logs, or wifi.
    Seems this started after TiBu went from version 5.5.1 to 5.5.2 (and 5.6).
    10-01-2012 03:55 PM
  25. Empty Hand's Avatar
    I have only had that problem with restoring wifi access points (SMS and call logs have always restored fine). I think I solved the wifi restore by making sure my wifi is turned on before restoring. It may be a coincidence, but try that.
    On a separate, but related note, I found I can cut a few steps out of my clean flashing if I go through the Google login instead of skipping it. That restores my wifi access points automatically, and I'm now always logged in to my Google account. Then I just stop the auto restore and go through the other TiBu restore steps.
    10-01-2012 04:31 PM
177 ... 23456 ...
