Page 4 of 77 FirstFirst 1234567 ... LastLast
Results 76 to 100 of 1915
Like Tree420Likes
  1. #76
    joeweav's Avatar
    Posts
    Carrier
    AOKP b38
    Default
    First off I want to thank everyone for all their hard work in keeping the community informed of all the JB ROMs and builds. I've learned a TON in the last month since I joined,rooted and flashed my GN. I recently flashed preview 1 but thought I should probably stay with something more stable until AOKP released something official so I decided to go with jellybro's latest 722. I noticed on euroskanks site this ROM from AOKP? What is this? I thought AOKP did their own thing?
    http://fitsnugly.euroskank.com/?rom=aokp&device=toro
  2. #77
    SeigaGen's Avatar
    Posts
    Global Posts
    699 Global Posts
    Carrier
    Kang/CM10
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    Quote Originally Posted by SeigaGen View Post
    Out of curiosity. Is Picasa sync working for everyone?
    nevermind. Fixed it by reinstalling gapps and fixing permissions.
  3. #78
    AZDROIDX's Avatar
    Posts
    Carrier
    Bugless Beast- GNex
    Quote Originally Posted by davey11 View Post
    Aokp just doesn't have themeing at the moment. I just plain cannot run a stock looking rom.
    It will exceed anything shortly theme wise until then, ***** on dark jelly is good.
    Same here, installed P1 and have Nandroid but now back on B40 on GNex because I love my custom brushed looking cyan softkeys with an Android as my Menu key. Not too mention a few apps JB still isn't compatible with, like HBO GO that just got upgraded for ICS. weeks ago. I ran EOS JB on my Xoom for a few days and returned to ICS too because of HBO GO, I like Flash on my browsers too.
  4. #79
    ekinnyc's Avatar
    Posts
    Global Posts
    424 Global Posts
    Carrier
    JB Viciousness
    Quote Originally Posted by joeweav View Post
    euroskank
    probably a kang of AOKP, just like they kang'd CM
  5. #80
    dmmarck's Avatar
    Retired Moderator
    Posts
    Carrier
    What do you think?
    Default
    Quote Originally Posted by nycinek View Post
    Yup. Appears to be based on the pre preview released a few days back.
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
  6. #81
    smr0416's Avatar
    Posts
    Carrier
    Bugless Beast 4.1.1
    Default
    Currently rocking Build 3 and it's awesome, very smooth (once I got rid of Nova of course =])
    Only problem I'm running into is voice search not working. Anyone else experiencing this or would this be a problem with the Gapps I flashed?? Thanks
  7. #82
    svfd757's Avatar
    Posts
    Global Posts
    834 Global Posts
    Carrier
    Cm 10/Franco
    Quote Originally Posted by smr0416 View Post
    Flashing now. One thing you could do to speed up nova is go into settings and change the animation speed to "light speed" or whatever. Works way better for me. I'll report back on google voice shortly
    NotJustAPhone likes this.
  8. #83
    dmmarck's Avatar
    Retired Moderator
    Posts
    Carrier
    What do you think?
    Default
    Put nova on light speed, all will be fine.
    Voice search works fine for me. Check your settings, make sure an offline language pack is there.
  9. #84
    kca2000's Avatar
    Posts
    Carrier
    "Shiny" Stock Android
    Default
    Really impressed with build 3 so far. First working app restore for me out of any of the JB builds I've tried. No force closes yet as well.
    dmmarck likes this.
  10. #85
    svfd757's Avatar
    Posts
    Global Posts
    834 Global Posts
    Carrier
    Cm 10/Franco
    Default
    Voice search working here
  11. Thread Author  Thread Author    #86
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    7,469 Global Posts
    Carrier
    BB JB
    argh by preview 3 link is down.
    anyone have a link I could replace it with?
  12. #87
    dmmarck's Avatar
    Retired Moderator
    Posts
    Carrier
    What do you think?
    Quote Originally Posted by tony bag o donuts View Post
    Check the RW thread, there's a folder with both preview 3 and a new 7/23 GAPPS package.
  13. #88
    ekinnyc's Avatar
    Posts
    Global Posts
    424 Global Posts
    Carrier
    JB Viciousness
    what does 7/23 gapps pack come with? is it like kejar's with JB versions of apps?
  14. #89
    steveinil's Avatar
    Posts
    Carrier
    aokp 34
    Default
    Crap I just downloaded the 7/17 gapps lol
  15. #90
    dmmarck's Avatar
    Retired Moderator
    Posts
    Carrier
    What do you think?
    No idea. I'll tell you once Preview 4 drops and I have a reason to flash it .
    zero neck likes this.
  16. #91
    2defmouze's Avatar
    Posts
    Carrier
    AOKP
    Yeah according to xoomdev it should have the JB versions.
    dmmarck and ekinnyc like this.
  17. #92
    ekinnyc's Avatar
    Posts
    Global Posts
    424 Global Posts
    Carrier
    JB Viciousness
    Quote Originally Posted by dmmarck View Post
    are you still on cm10?
  18. #93
    dmmarck's Avatar
    Retired Moderator
    Posts
    Carrier
    What do you think?
    Nope. I'll probably hop back on if Preview 4 doesn't drop within the work day lol.
  19. #94
    Promoman89's Avatar
    Posts
    Global Posts
    127 Global Posts
    Carrier
    JellyBro I Trinity
    been wanting to try an AOKP build for sometime... so downloading now... looking forward to seeing what its all about
  20. #95
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Carrier
    KANG
    anyone know if aokp backup app works with jb builds yet?
  21. #96
    dmmarck's Avatar
    Retired Moderator
    Posts
    Carrier
    What do you think?
    Quote Originally Posted by zero neck View Post
    Haven't heard; saw it asked on RW but I don't think anyone has actually tried it lol
  22. #97
    ekinnyc's Avatar
    Posts
    Global Posts
    424 Global Posts
    Carrier
    JB Viciousness
    yeah, that was me. seems like not.
  23. #98
    dmmarck's Avatar
    Retired Moderator
    Posts
    Carrier
    What do you think?
    LOL whoops, my apologies. Things move so quickly sometimes .
  24. #99
    ekinnyc's Avatar
    Posts
    Global Posts
    424 Global Posts
    Carrier
    JB Viciousness
    haha, thanks, none needed.
    trying to catch up to what i missed over the weekend
  25. #100
    kca2000's Avatar
    Posts
    Carrier
    Default
    Tony you can post my link from the previous Page if that helps. I'll leave it up till build 4 comes out. If anyone needs a mirror for gapps send me a link for it and ill mirror that too.
Tags for this Thread
