Page 61 of 77 FirstFirst ... 58596061626364 ... LastLast
Results 1,501 to 1,525 of 1915
Like Tree420Likes
  1. #1501
    EvanM3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    Quote Originally Posted by dmmarck View Post
    Everyone with M1, can they try the clock thing I described?
    Go to Settings, then ROM Control, then Clock. Set "short press" (or whatever the hell the other option is that isn't long press), select "Alarms."
    Go to the home screen, pull down the notification drawer, and tap the clock. Force close?
    I tried it and I get nothing. On the other hand, long press for alarm works as it should. No force close though
  2. #1502
    nexusisneecesary's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Viper(HTC)One
    yes it happened to me earlier today
  3. #1503
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Quote Originally Posted by EvanM3 View Post
    Does it popup with the alarm? Hmmm...I may do long press and see what's what. Thanks!
    - - - Updated - - -
    Quote Originally Posted by nexusisneecesary View Post
    Thanks!
  4. #1504
    mraviator's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Force close?
    That's affirmative. Force close here too.
  5. #1505
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Quote Originally Posted by mraviator View Post
    Thanks, at least I know I'm not nuts lol
  6. #1506
    Patrick Schroedl's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,827 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    - - - Updated - - -
    Thanks!
    Since it might not be happening to everyone, something to try would be seeing if the issue changes depending on whether or not you actually have alarms set/turned on.
  7. #1507
    EvanM3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I set some alarms and then tried the short press. Still nothing. The alarms don't even open or anything. No force close.
    Long pressing the clock does work like it should.
  8. #1508
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    It's so weird. Works like a charm on the grouper. In the end, it's a minor issue, but still--was looking forward to not having to open the app drawer for my alarms .
  9. #1509
    weasle543's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Alarm clock worked this morning, I made it to work on time. :-)
    dmmarck likes this.
  10. #1510
    jmorosky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOSPA 3.99/ Golden Kernel
    Short click FC'd for me the first time but has worked every other time I tried. But I also had alarms set for long click too.
    Sent from my Island using my Smoke Monster
  11. #1511
    weasle543's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It would force close until I set the short and long press to something different.
  12. #1512
    finger11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I'm about to flash Milestone 1. Which gapps should I be flashing with this ROM? Thanks guys!
  13. #1513
    2defmouze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Quote Originally Posted by finger11 View Post
    They are linked at the end of the download list on aokp.co
  14. #1514
    finger11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 2defmouze View Post
    Right on, so that's how you know which to use.
  15. #1515
    mraviator's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was running MS1 for two days with no issues. Then I realized my Gmail emails weren't being pushed. Sure enough, sync was turned off. I can't say for sure this happened on its own, but has anyone experienced similar?
  16. #1516
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    90% sure that with the new GAPPs, which require Gmail to be downloaded separately, that sync needs to be tapped/selected.
  17. #1517
    mraviator's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ahhh.... that also explains why I had to download gmail separately. Thanks.
  18. #1518
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    While not AOKP-related, I'm curious, is there anything in the franco kernel app that I should play around with in the settings that will boost performance/ battery life in any way?
    Edit: I managed to dig up an old picture from dmmarck, and by matching the settings as closely as possible, it seems my battery is doing a lot better! This was his pic, just for reference:
  19. #1519
    jova33's Avatar
    Posts
    Global Posts
    364 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think jelly bean is supposed to work best with interactive.
    Sent from my wireless telephonic device.
  20. #1520
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Really? Hm. Its been working fine for me with "ondemand". Then again, I don't know what any of those settings actually mean/ do at all, so...
  21. #1521
    jova33's Avatar
    Posts
    Global Posts
    364 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Neither do I lol. I just know what I hear. Like people have been saying the x governors are choppy. Interactivex, hotplugx, and so on.
  22. #1522
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Stock jelly bean governor is interactive, that's why .
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
  23. #1523
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So, is there anything I should be aware of, by setting mine to "ondemand"? What does that mean for my phone, and what is the difference between using "ondemand" or "interactive"? Is there some sort of noticeable difference at all?
  24. #1524
    anthony1117's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Enjoying this ROM a lot. Found few bugs, my clock in the right crner and th one at the top of my pull down do not auto matically update the time.....Kinda confusing and frustrating,. Does anybody else have this problem or is it just me. SHould i try a reset and reinstall? Any suggestins would be awesome.
  25. #1525
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by anthony1117 View Post
    Mine changes perfectly. Try a full wipe and reinstall
Tags for this Thread
