Page 68 of 77 FirstFirst ... 65666768697071 ... LastLast
Results 1,676 to 1,700 of 1915
Like Tree420Likes
  1. #1676
    2defmouze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    Quote Originally Posted by KYHusker View Post
    So I updated TWRP Recovery, wiped dalvik/cache/system, then flashed AOKP 4.2.1, then the new gapps, then a tibu zip. Wiped dalvik/cache after each flash. Great. But instead of having to restore the tibu backups and nova settings, everything was in place just as I left it before the new ROM was flashed, as if I did a dirty flash.
    OK less work but it seems like I did something wrong.
    Any ideas ?
    AOKP Backup thinks I am not on an AOKP ROM now btw.
    If you didn't wipe data then you did a dirty flash, that's why all your apps are still there and settings. Also wiping cache/dalvik between flashing those items is redundant, you don't need to at all. Thirdly, I'm pretty sure Roman hasn't updated the AOKP backup app yet for the new builds, which would explain why it doesn't recognize the ROM.
    KYHusker likes this.
  2. #1677
    mraviator's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm using CWM 6.0.2.3. Is there any need to switch to TWRP before flashing to 4.2.1?
  3. #1678
    2defmouze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Quote Originally Posted by mraviator View Post
    Shouldn't need to.. though I recommend TWRP as well as most other people, I believe Team Kang does, too.
  4. #1679
    mraviator's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks. Curious why TWRP seems to be the gold standard....
    Guess I should look into switching over if everybody recommends it.
  5. #1680
    KYHusker's Avatar
    Posts
    Global Posts
    61 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP JB mr1 Milestone 1
    Quote Originally Posted by 2defmouze View Post
    So in TWRP wiping dalvik/cache/system doesn't wipe data? Does "factory wipe" = data wipe? Didn't want to empty the SD partition.
    Maybe it has been too long since I flashed anything new. But thanks to AOKP for the new ROM.
  6. #1681
    2defmouze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    In both TWRP and CWM if you don't do "Wipe data/Factory reset" you are dirty flashing... the sdcard partition does NOT get wiped by either custom recovery when you do this though. Yeah you're just out of practice
    KYHusker and NotJustAPhone like this.
  7. #1682
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was always a CWM guy, myself, but then I had a very scary experience in which my Transformer Prime bricked because of CWM. I was able to get it working again, and ever since then, I've stuck to TWRP. Not that CWM is any more likely to cause problems (to my knowledge, anyway...?), but after that little scare, I certainly didn't want to take any chances anymore.
    I'm curious as to how frequent these new AOKP builds will be. I wonder if they'll be like a weekly thing, or bi-weekly, etc.?
    AZDROIDX likes this.
  8. #1683
    KYHusker's Avatar
    Posts
    Global Posts
    61 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Backing up data - flashing ROMs and ZIPs - restoring data is so much more fun when you do it the right way.
    Thanks for the help as always 2defmouze!
    2defmouze likes this.
  9. #1684
    AZDROIDX's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Bugless Beast- GNex
    Quote Originally Posted by MRW1215 View Post
    Spent some time this morning flashing the new official build and getting my phone all set up again. Pretty happy to be back on "official" AOKP, instead of those DizzyThermal nightlies, though I don't immediately notice many differences. One thing I really dig, though (and this might always have been possible in AOKP, but it seemed to be the "default" when I flashed this new ROM) is the transparent navbar, and the option to adjust the transparency of the status bar, as well.
    Still slightly annoyed they haven't got the ability to change lockscreen wallpaper in yet, though. I mean, not "annoyed" like really mad, it just doesn't seem like something that would be super difficult to implement, and it hasn't been in any of the DizzyThermal nightlies (which have been coming out for a while now), nor in this new official build.
    The transparent nav started for me on the Unofficial SkankAOKP of 1-1-2013, pretty cool. Keep mine at 50% for that perfect transparent look. I'm now on the Unofficial 1-4-2013 as of this morning.
  10. #1685
    ConTejas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Latest OS + EX kernel
    After running mr1 for a day, I'm have to say the official builds are none the better than the unofficial compiled builds I've been dirty flashing for weeks. It's great, just not any better or more stable. If anything, a bit less saucy than my last aokp linaro combo, but it's still zipping. Just noting for you "official only" folks. It makes sense becuase devs like DizzyThermal and EuroSkank only compile nightly builds from offical aokp (and CM) gerrit releases. That said, YMMV. I'm sure there are some things in the compiling/building process that leaves room for error so they certainly get my respect and appreciation for taking their time to do it and share.
  11. #1686
    mraviator's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks everyone for getting me to switch from CWM to TWRP. It's great, I like it.
    wyseguy77 likes this.
  12. #1687
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    anyone running the aokp 4.2.1 build. does it support miracast im currently using another rom that does and its become very handy when trying to show off information at meetings
    thanks guys
  13. #1688
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've noticed that if the phone sits for a bit and than picked up to use, the connections are greyed out and seem to have a hard time reestablishing the connection. I don't know if that is because of the kernel I'm using or something to do with this build or 4.2.1 in general
  14. #1689
    CallerHoller's Avatar
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Explicit View Post
    I've noticed that of the phone sits for a bit and than picked up to use, the connections are greyed out and seem to have a hard time reestablishing the connection. I don't know if that is because of the kernel I'm using or something to do with this build or 4.2.1 in general
    I had the idle greyed out wifi and data come and go with different nightly builds from @fitsnugly. I didn't have it with the Dec 21build and I don't have it with the Official build.
    Attempting to ask @fitsnugly only results in him berating you claiming his works fine it's your fault.
    Anyway the issues coming and going from one night to another is bewildering.
  15. #1690
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hmmm I just flashed a different kernel. I'm hoping that's fixes it. I'm on the official build as well. Guess it's time to test it out and see what happens.
    ScottiePP7 likes this.
  16. #1691
    wyseguy77's Avatar
    Posts
    Global Posts
    293 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What kernel are people using? I've been using Franco but an thinking of giving another one a shot.
  17. #1692
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by wyseguy77 View Post
    I use the Jame Bond kernel
    http://forum.xda-developers.com/show....php?t=1414364
  18. #1693
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've not played with different kernels. What ever kernel is in the nightly has been fine for me.
  19. #1694
    ConTejas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stayed on the lean kernel 5.4 that came with mr1 @ 1350MHZ/interactive...very buttery and stable so far and I like the colors (usually mess with them).
    mraviator likes this.
  20. #1695
    Skis X's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Steve posted a new unofficial PUB build 6Jan on his androtransfer. running great with lean kernel 5.6
    10001110101 likes this.
  21. #1696
    7stringer's Avatar
    I have The Rickets
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Rooted and Ever-Changing
    My bluetooth has been wonky - connects to my car sometimes, and then at times gets stuck "turning bluetooth off." And, oddly, the sound quality/volume is nowhere near as nice as it was when I was on the 4.1.2 M1 build. Oh well, here's to hoping the next wave is fine.
    I still get some systemUI crashing, but not as much. Might have to say farewell to AOKP soon and try out some CM builds.
  22. #1697
    AZDROIDX's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Bugless Beast- GNex
    Quote Originally Posted by Skis X View Post
    Is this AOKP PUB new? I'm running the latest unofficial ***** AOKP but I see it's no longer listed on GooManager, so am I stuck on Build Jan 4 from them? Thanks.
  23. #1698
    10001110101's Avatar
    Posts
    Global Posts
    397 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    There will be many...
    Quote Originally Posted by AZDROIDX View Post
    http://androtransfer.com/?developer=stevespear
    Flash in combination with the latest Gapps. I've been running it since the first release with no issues. Just flashed Leankernel 5.6 over it today.
    Butter.
  24. #1699
    AZDROIDX's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Bugless Beast- GNex
    Quote Originally Posted by 10001110101 View Post
    androtransfer.com
    Butter.
    Thanks for link, so since this is a totally different Dev it seems, I would need to backup and wipe to try this new ROM instead of *****'s AOKP?
  25. #1700
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Looks like my issue was kernel related as it was a "test" kernel and not the developers official one. The official Jame Bond 3.7.1 works perfect. Hopefully it stays that way. Still wondering where the weather ability in MR1 is at....
Tags for this Thread
