Page 69 of 77 FirstFirst ... 66676869707172 ... LastLast
Results 1,701 to 1,725 of 1915
Like Tree420Likes
  1. #1701
    CallerHoller's Avatar
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    My Twitter app isn't updating on today's build. Kinda annoying. On par with the usual bugs that come and go with the nightlies.
  2. #1702
    10001110101's Avatar
    Posts
    Global Posts
    397 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    There will be many...
    Quote Originally Posted by AZDROIDX View Post
    Thanks for link, so since this is a totally different Dev it seems, I would need to backup and wipe to try this new ROM instead of *****'s AOKP?
    You may be able to dirty flash it, but I usually go clean when changing developers.
  3. #1703
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Twitter is chirping away at work this morning. I'm guessing that my issue at home was the idle wifi Grey out. No biggie.
  4. #1704
    finger11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Anyone else having an issue with wifi disconnecting when the phone goes idle/sleep? I have it checked that wifi stays on during sleep, but when I unlock my phone it has to reconnect to my wifi.
    edit: going to try a different kernal
  5. #1705
    Skis X's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    New PUB build from Steve.
    androtransfer.com
  6. #1706
    AZDROIDX's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Bugless Beast- GNex
    Thanks, the ***** AOKP folder is back up on GooManager and I flashed 1-10-13 this morning. I'll stick with it.
  7. #1707
    Skis X's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Steve's latest PUB build is blazing fast. It's got its own thread over on rootz: Stevespear PUB AOKP builds - Project Unicorn Butter - AOKP - RootzWiki
    AZDROIDX likes this.
  8. #1708
    finger11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Maybe I just never noticed it before, but under battery should the "GPS on" blue bar be full from left to right and the Maps application using up the most battery? I don't have GPS on and I even Forced Stopped the Maps app, but the Maps Use Details (says GPS) still increases by the second. I even tried shutting off all Location Access.
    Using MR1 and Lean Kernal
  9. #1709
    Posts
    Global Posts
    397 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by finger11 View Post
    I had a nasty wakelock with Google Maps. After un-installing and re-installing it went away. Are you using Titanium Backup? I only ask since I feel that the issue stems from restoring from there. I know that I have issues with Facebook re-installs from Titanium as well.
    ConTejas and finger11 like this.
  10. #1710
    finger11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 10001110101 View Post
    Yea I used TB. I just uninstalled and reinstalled and looks like Maps isn't on the battery screen anymore, thanks.
    10001110101 likes this.
  11. #1711
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I saw a video on Twitter showing off a work-in-progress feature that allows you to hide the navbar (and swipe up from the bottom to make it pop up). That seems like a neat little feature, hope we see it soon.
  12. #1712
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That would be nice on my next device.(Nexus 5) However my notification and nav bars have burned in on my GN. There are clearshadows when a video stretches out the screen.
  13. #1713
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I haven't had that problem, myself, but I've feared it enough to shy away from using certain apps, and whatnot, that might've kept the screen on long enough to do that.
  14. #1714
    Isamu982's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by CallerHoller View Post
    Is your brightness turned up a lot?
  15. #1715
    anthony1117's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Running JB Mr1 the 4.2 one. Sick stuff. Also flashed the latest lean kernel. 5.8. Sick battery life. Been listening to tunes all day at work and still have 30% battery. Loving this!!
    Also if they read this. Instead of tiles i would love to see switches in the toggle menu. Like the quick access in the other menu but think switches look cooler.
  16. #1716
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by anthony1117 View Post
    That's a 4.2 feature by Google
  17. #1717
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Has anyone else noticed an issue in which the stock keyboard no longer automatically corrects typing just "i" to the capital "I"? It used to correct to "I" for me when I was using the DizzyThermal 4.2 nightly builds, then at some point, it stopped correcting to the capitalized version. I did a full wipe when I flashed to the official AOKP MR1 release, and it still doesn't autocorrect to "I". Kind of annoying, especially considering I do a lot of typing on my phone.
  18. #1718
    wyseguy77's Avatar
    Posts
    Global Posts
    293 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by chuazy View Post
    the native music app is not as appealing and easy to navigate than iPhone thats for sure.. but the speaker is pretty loud and clear....
    video play back too, and still not happy with the apps in the market for it
    i noticed this too.
  19. #1719
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MRW1215 View Post
    I've noticed this issue on MR1 only. M1 worked fine.
  20. #1720
    ultravisitor's Avatar
    Posts
    Global Posts
    2,881 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    MR1 Build 2 is out.
    jmorosky likes this.
  21. #1721
    jmorosky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOSPA 3.99/ Golden Kernel
    JB-MR1 Build 2 is up.
  22. #1722
    Canuckfan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM10 JellyBro | Franco M5
    Quote Originally Posted by Skis X View Post
    Has any of Steve's work (specifically the Linaro optimizations) been merged with the latest MR1-Build 2 release?
  23. #1723
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    MR1-Build 2 fixed this issue, for me at least
  24. #1724
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Explicit View Post
    Ah, thanks, I didn't even know a new build was out! The issue has been fixed for me, too!
    But, after flashing this new build, I decided to take a peak at the "performance control" thing they added in the settings, and I accidentally touched something and threw off my performance settings a bit... I don't remember what they were before I touched anything, so I don't know how to reset them. :/ Anybody that's more savvy with that kind of thing that can suggest how I should have those settings adjusted? For what it's worth, my priority is battery life, so whatever is going to maximize my battery life, that's what I want.
  25. #1725
    7stringer's Avatar
    I have The Rickets
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Rooted and Ever-Changing
    Are you using the stock Kernel, MRW? If not, just reflash whatever kernel you have (like Franco or something) and the stock settings for that kernel should populate. In general, I run interactive governer with stock 1228 speed.
Tags for this Thread
