Page 71 of 77 FirstFirst ... 68697071727374 ... LastLast
Results 1,751 to 1,775 of 1915
Like Tree420Likes
  1. #1751
    wyseguy77's Avatar
    Posts
    Global Posts
    293 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    Quote Originally Posted by Empty Hand View Post
    In my experience, sometimes apps auto restore and sometimes they don't. They have with the 1212 gaaps. Personally, I find it a waste of time for auto restore. Check out the "how to tibu the easy way" thread for great instructional using titanium backup. It's much faster and easy after you get the hang of it. Your contacts will follow your Gmail account and your other mail accounts so that shouldn't be an issue. Good luck!
    This!
    Xanth269 likes this.
  2. #1752
    TabGuy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Xanth269 View Post
    Has anybody used TWRP to install/flash the rom and gapps? if so any issues with it? seems to be a easier way to flash for thise of use like me that are not crack flashers. Also used goomanger to update TWRP today.
    Works fine for me.
  3. #1753
    steveinil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    aokp 34
    anyone elses kangerator app stopping? was im running build one and saw 2 was out and opened no luck even uninstalled and re installed same thing ?
  4. #1754
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Anyone seen your phone change wallpapers on its own after being on for a day or so? You can't change it back either. A reboot restores everything though, but definitely an odd bug
  5. #1755
    steveinil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    aokp 34
    Yep does that to me too but then changes back on it's own too to the one i had set lol
  6. #1756
    steveinil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    aokp 34
    Quote Originally Posted by Explicit View Post
    O you can quote using the app lol
  7. #1757
    Jubakuba's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    asdfasdf
  8. #1758
    steveinil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    aokp 34
    Quote Originally Posted by Jubakuba View Post
    Synced at ID > Iceb68574
    Built Using ALL PUB (Project Unicorn Butter - Steve/BMC's Project) Tweaks
    Cherries
    ________
    ________
    Framework:
    All Needed ROMControl/Settings Tie-Ins
    Added Swagger to SwaggerTile (Sundays!)
    Replace CandyCane With TeamKang Cogs
    RomControl:
    Dual Panel CheckBox
    Recent Apps GB Style
    Lockscreen Wallpaper
    Allow Custom Icon Tinting Option
    Menu UI Overflow Toggle
    Transparency Control Overhaul (Moar Stuffz)
    Quick Unlock
    Hiding NavBar
    Camera:
    Added Shortcut To Gallery in Camera Switcher
    DeskClock:
    Flip & Shake to Snooze/Dismiss
    Increasing Ringer Volume
    Settings:
    Volume Adjust Sound Preference (Silence the sound of changing Volume)
    Increase MMS limit
    Download:
    TORO
    GROUPER
    OK is this an update for AOKP or a different rom? Was looking for some more customization this sounds pretty sweet if it's a different rom then i assume no dirty flash?
  9. #1759
    CallerHoller's Avatar
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by steveinil View Post
    This is a nightly or weekly update. Unofficial update to MR1 Official release. @fitsnugley releases a nightly too. I believe this one uses a different Kernal. I flashed it and it's stable and buttery.
  10. #1760
    steveinil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    aokp 34
    Quote Originally Posted by CallerHoller View Post
    Did you do a compete wipe or dirty?
  11. #1761
    steveinil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    aokp 34
    Currently running mr1 build 1
  12. #1762
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I always clean wipe. It's so quick, I don't see the point of dirty flashing.
    I've read that you should only dirty flash if you're updating the same ROM. If it's a different ROM or even a different kernel should be wiped.
    steveinil likes this.
  13. #1763
    Jubakuba's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    paspfdoafsd
    Empty Hand and Canuckfan like this.
  14. #1764
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Jumped back to mr1. I kept having silent SMS. Drove me crazy.
  15. #1765
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Build 3 is out.
    [Release] JB-MR1 Build 3 | AOKP
    Downloading it right now.
    bbudnick5001 likes this.
  16. #1766
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My only complaint thus far is that the hidden navbar option isn't quite as nicely done as that "pie" style other devs are now rolling with. In particular, it's kinda annoying when you have a "kill all" button enabled in your recents screen, because when you go to your recents, the navbar covers the button up and you have to wait a second or so for it to go away.
  17. #1767
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    D'oh, what the...? I backed up my current set up via TWRP, then I wanted to try out another ROM for a quick sec. Didn't like that other ROM, so I restored my backup, and while my stuff basically restored, all of my AOKP and Apex Launcher settings are back to "defaults".
  18. #1768
    Empty Hand's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MRW1215 View Post
    Check out Roman's AOKP Backup app. He just updated it and it's working well. That will take the aokp settings issue in the future.
  19. #1769
    weasle543's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Installed build 3 Monday afternoon, ran it until Wed morning. UI was too laggy, went back to build 2.
  20. #1770
    Xanth269's Avatar
    Posts
    Global Posts
    503 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    can you post link?
  21. #1771
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I haven't noticed a lag with MR1 bld3. Just glad it doesn't have wifi idle issue and silent notifications.
  22. #1772
    Empty Hand's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    can you post link?
    https://play.google.com/store/apps/d...om.aokp.backup
  23. #1773
    Xanth269's Avatar
    Posts
    Global Posts
    503 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    THANKS!
  24. #1774
    7stringer's Avatar
    I have The Rickets
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Rooted and Ever-Changing
    I did a dirty flash of this, had issues, and then did a full clean flash. I'm having all sorts of lag, freezes, lockups, etc. Had issues with systemUI crashing since they switched to JB. I think I'm done with AOKP for a while.
    Need to find something super stable. JB has baked in the things I used to need from a ROM (toggles), so I need something clean.
  25. #1775
    Canuckfan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM10 JellyBro | Franco M5
    New unofficial build from adam based on 4.2.2!
    Goo.im Downloads - Downloading aokp_toro_unofficial_Feb-15-13.zip
    oxymoron likes this.
Tags for this Thread
