Page 77 of 77 FirstFirst ... 74757677
Results 1,901 to 1,915 of 1915
Like Tree420Likes
  1. #1901
    jmorosky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOSPA 3.99/ Golden Kernel
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    Quote Originally Posted by tony bag o donuts View Post
    Sorry I switched to mmuzzy french vanilla...
    I'm giving PA a go now. I was on CM for a bit too.
    Sent from my Galaxy Nexus using Tapatalk 4 Beta
  2. #1902
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Man, ribbons are pretty cool! I set up my left swipe ribbon to have my favorite most used apps, and I set up my right swipe ribbon to have direct dial (or long press to text message) buttons for my most contacted, er, contacts. At first, I was having issues with the drag handles pulling out when I was using the keyboard, but the options in the settings let me position the drag handles at the perfect place so as not to conflict with the keyboard. I like it!
    Just out of curiosity, though, how do you make the other ribbons activate, if you have them turned on? I mean, things like swipe left/ right/ bottom/ top are pretty easy to figure out (just swipe from the specified area of the screen), but what is the lockscreen ribbon, notification ribbon, toggle ribbon, etc.? If you enable them, how do you pull them out?
  3. #1903
    Jubakuba's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MRW1215 View Post
    Keyboard Issue:
    There is an option to disable swipes while the keyboard is up, FYI.
    Other Ribbons:
    Notification Ribbon is found in your notification shade.
    Lockscreen Ribbon is found on your lockscreen.
    Toggle Ribbon is found in your toggles shade.
  4. #1904
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm sure someone already knows about this, but I figured I may as well post about it just in case. Think I may have found a bug with the nightly from the 12th. On the lockscreen, when you swipe right for the camera, the phone reboots. Never did this before I flashed this nightly.
  5. #1905
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    New Milestone incoming...
    Xanth269 likes this.
  6. #1906
    Explicit's Avatar
    Posts
    Global Posts
    329 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    AOKP JB milestone 2 out now
  7. #1907
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Man... I decided to give the LiquidSmooth ROM a try, and I'm so torn, now. I felt like I was noticing a bit of lag and whatnot on AOKP, and LS feels a lot smoother. Not to mention, I really like the baked in pie controls in LS; using AOKP with LMT isn't so nice, because LMT itself seems to have errors with responsiveness and whatnot, and having the pie controls baked in makes the experience so much better, but from what I remember, someone said AOKP will never bake in pie controls. :/
    At the same time, I really miss the AOKP Ribbons, and a bunch of other little customization stuff from AOKP.
    It really sucks that there can't just be one ROM that covers all the bases. *sigh*
  8. #1908
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, decided to make the jump back to AOKP + LMT. Thus far, Milestone 2 and the latest version of LMT seem to be playing nice with each other, and I haven't noticed much lag or slow down, as compared to the previous nightly builds of AOKP and LMT version 1.99.
  9. #1909
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hah, it's unfortunate that AOKP put out a new milestone just before a new version of Android came out. Now I find myself itching for the first 4.3 milestone. @_@
  10. #1910
    jova33's Avatar
    Posts
    Global Posts
    364 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well they put out the 4.2.2 milestone basically because it's the last 4.2.2 build and they wanted to make a stable version for those who only flash milestones.
    Sent from my SCH-I545 using Tapatalk 4 Beta
  11. #1911
    Xanth269's Avatar
    Posts
    Global Posts
    503 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    is Milestone 2 stable for a Gnex? been reading on other boards some people are having issues. interested in the jump still been on a pre- Milestone 1 build, it works and does what I want i'm no crack flasher but do like to have the newest software if its works properly.
  12. #1912
    MRW1215's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I first flashed it, it was working pretty great. For whatever reason, though, lately I've been experiencing a lot of lag and slow down in Chrome. Weird that this is just happening now, considering I haven't flashed or installed anything new since.
  13. #1913
    Xanth269's Avatar
    Posts
    Global Posts
    503 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have read a lot of people are having issues with Chrome and they have suggested going to either Firefox or stock browser.
    Any issues with GPS or navigation, that was always my issue when flashing.
  14. #1914
    Xanth269's Avatar
    Posts
    Global Posts
    503 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok so its been awhile since I flashed , was running Build 5, than I flashed the July 27 nightly and than a newer nightly was released, is it OK to dirty flash between nightlies?
  15. #1915
    Empty Hand's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Xanth269 View Post
    Yes, but if you have any issues with the newer nightly, do a clean flash before reporting issues.
Tags for this Thread
