Empty Hand
G
I think there will be more Franco updates, but possibly not until 4.2.2 is released. I have recently switched to leankernel. I can't say I see major differences. I'm getting just as good battery life. My switch was largely because of my crack flashing habit and just wanting to update my kernel. To get a bit of the best of both worlds, I've been using the franco app to use franco's best balance power mode that allows certain frequencies that leankernel doesn't otherwise have easily available.
Edit: New Franco kernel out today. Happy flashing!
Since there apparently aren't going to be any more franco kernel updates, I'm finding myself wondering if I should switch to using leankernel. Though, I'm not really sure if it's that worth it at all. I can't imagine there are any major noticeable differences, right?
