[ROM][4.1.1][AOSP] Codename Android 3.0.0 [JB][07/31/2012]
VAVA Mk2
364
12
NOTE: I do not take ANY credit related to the creation of this ROM. Just an enthusiast sharing the word with people on our great forums who want to give this a shot/show interest :)
CodeNameAndroid.com Forum Thread
http://codenameandroid.com/forum/index.php?/forum/25-rom-releases/
CNA ROM Downloads (newer versions will show up here)
http://goo.im/devs/codenamedroid/stable/GalaxyNexus-VZN
GAPPS
http://goo.im/devs/codenamedroid/googleapps
Android Authority's Video Walkthrough of 3.0.0
http://www.youtube.com/watch?v=WJm8CuGl8OU&feature=player_embedded
_________________________________________________________________________________________________________________
FEATURE LIST
* Based off of Clean Android 4.1.1 Rev6 (JRO03R)
* File Manager Included
* T-mobile Theme Manager (tmobile, CyanogenMod, xoomdev)
* T9 Dialer/Landscape/Dialpad Settings (CyanogenMod)
* Trebuchet Custom Launcher (CyanogenMod)
* Ability to set custom ringtone delay (in phone settings - Netboy)
* Framework: added support for caller name display (kenshin)
* Framework: added HSPA+ support (shows H+ icon on status bar when connected to hspa+ - Bajee11)
* Framework: ability to set custom carrier label (Netboy)
* Browser: option open tab in incognito mode (Arham Jamal)
* Browser: option to close all other tabs (Arham Jamal)
* Browser: unhid the user agent settings
* DeskClock: added stopwatch and countdown timer (Jorge Ruesga)
* DeskClock: added settings to do nothing/snooze/dismiss and alarm by flipping the device (maurodec)
* DeskClock: you can set an alarm to switch your profile (jorge ruesga)
* Email: added meeting time to email invitation tab (erezak)
* Email: added option to enable/disable LED notifications per email account (apohl79)
* Keyboard: ability to use the volume buttons to move the cursor (romanbb)
* Settings: ADB over Network (enable TCP/IP debugging over Network interfaces (WiFi, Usb networks)
* Settings: Added option to disable volume adjustment sound (Settings -> Sound - StevenHarper)
* Settings: Option to change the devices hostname
* Settings: Hardware info in about phone (romanbb)
* Settings: Added nfc poling (sethyx)
* Custom Camera App: (CyanogenMod)
- Continuos focus
- Iso Support
- Support for red eye reduction
- Ability to use the power button to take pictures
* Customizable Messaging App:
- Added the ability to display a pop-up QuickMessage when an Sms message is received (DvTonder)
- Added call sender and quick reply notification actions (DvTonder)
- Added Emoji patch from CM MMS app (Robert Burns)
- SMS Templates (rciovati)
- Custom Vibrations (mssmison)
- Timestamp Options (aravance)
* Customizable Phone App (CM)
- Advanced Phone settings (optional vib on outgoing or incoming call or every 45 seconds)
* Customizable Power Menu (codenamedroid)
- Reboot Menu
- Profile Switcher
- Screenshot
- Airplane Mode
- Navigation bar toggle
- Silent toggle
* Customizable Status Bar: (Miui, CyanogenMod, romanbb, sethyx, kejar, syaoran12 ,romanbb, Stevespear426, Kyle Teague, Whitehawkx)
- Battery Icon style
- Battery Icon in notification bar
- Miui style battery bar
- Clock style
- Customizable Clock Color
- Clock Am/Pm style
- Clock Day of the Week
- Customizable Signal Text
- Customizable WiFi Signal Text
- Ability to slide your finger across the status bar to control brightness
- Notification counter
* Customizable Notification bar:
- Notification bar Power Widget (Cvcps, DvTonder – CyanogenMod)
- Notification bar Toogles (AOKP - romanbb)
* Customizable Navigation Bar: (Zaphod-Beeblebrox, KhasMek, romanbb, akellar)
- Ability to enable/disable the navigation bar (enable toggle in power menu settings)
- Customizable navigation button actions
- Custom navigation bar ring targets (Team Eos, modified by Codenamedroid)
- customizable navigation bar color (Team Eos, modified by Codenamedroid)
- Customizable navigation button and button glow color
- Menu button visibility and location
- Number of navigation buttons
- Order of navigation buttons
- Navigation bar size
- Navigation bar transparency
* Customizable Lockscreen:
- Up to eight configurable lockscreen targets (Codenamedroid)
- Added optional centered lockscreen layout (Codenamedroid)
- Optional centered lockscreen clock
- Option to disable vibration on the lockscreen (StevenHarper)
- Customizable number of lockscreen targets (CyanogenMod)
- Configurable lockscreen wallpaper (Danesh M)
- Option to always show lockscreen battery (Blunden)
- Add weather to the lockscreen (DvTonder, Danesh M, Marius Volkhart, Rick C, Aokp)
- Add calendar reminders to the lockscreen (David Morgan)
- Lockscreen before secure unlock (Danesh M)
- Ability to unlock with menu (CyanogenMod)
- Quick pin unlock (unlock with pin/password without pressing ok – CyanogenMod)
* Customizable Sound Settings:
- Customizable volume panel (Stevespear426)
- Configurable ascending ringtone (Danny Baumann)
- Safe headset volume (CyanogenMod)
- Volume rocker music controls (CyanogenMod)
- Ability to customize action taken when connecting a headset (syaoran12)
- Face down actions (syaoran12)
* Customizable Display Settings: (CyanogenMod)
- Customizable Rotation Modes
- Customizable LED Pulse (Duration and Color)
- Volume wake (tap either the up or down volume key to wake your phone from sleep)
- Volume music controls (long press volume buttons to skip tracks)
* Custom Profiles (CyanogenMod)
- assign different profiles to change the behavior of your phone to your liking
* Quiet Hours (CyanogenMod)
- the ability to set when notification sounds, haptic feedback, vibration and notification light will function[/color]
* Performance Settings:
- Start-up tweaks (kejar, Jrummy)
- Processor Speed (xoomdev)
- Voltage controls (xoomdev)
- Kernel controls (kejar, Jrummy)
* Developer Options:
- Propmodder (Jdkoreclipse)
- Spare Parts
- Development app
- Testing Settings
EXTRA TOOLS
* SuperSU
* Busybox
* Bash
* Nano[/color]
FLASH
[New users]
1. Reboot into recovery
2. Wipe Data and cache
3. Flash rom
4. Flash Gapps
[Returning users]
2. Wipe cache only
3. Flash rom
4. Flash Gapps
Codename Android 3.6.5 – 3.6.6 Changelog
[additions]
* enables custom navigation bar keys and ring on 10inch tablets (Stevespear426)
* added the option to change the soft keyboard type when composing messages (GzFighter):
Gives the user the option to change the keyboard from Emoji to enter or a
new line or enter to send. The setting has no effect on the hardware keyboard.
* increased the default number of sms messages sent in checking period (TeamBAMF)
* added screenshot option to navbar settings (Stevespear426)
[general]
* updated navbar color picker (Patrick L)
[fixes]
* fixed audio wakelock on galaxy s3
* fixed reverting to 700mhz on screen on galaxy nexus
* fixed QuickMessage popup force closing when receiveing Mms and QuickMessage themeing support
* fixed switching custom navbar icons without resetting the navbar
Codename Android 3.6.0 – 3.6.5 Changelog
[additions]
* new Codename(Android) wallpapers -
(Codenamedroid, LordGarlicbeard, Paranoid Android)
* custom navbar icons - (Zaphod-Beeblebrox, modified to work with CNA)
* notification wallpaper - (xoomdev, modified to work with CNA)
* statusbar transparency - (Paranoid Android)
* re-added navbar color
* added force tablet and dpi change
(dagr8 - Settings -> Interface -> Gerneral UI)
* added alternate signal layout
(Zaphod-Beeblebrox - Settings -> Interface -> Status bar)
* added IME switcher and Ring/Vibe toggle as navring target
(Boris Bershadskiy)
* added IME toggler as Navbar target (Boris Bershadskiy)
* increased themeability of the statusbar (Zaphod-Beeblebrox)
* added the advanced calulator features from cm
* add alow mock sms to developer settings (jruesga)
* new command line tools:
htop, lsof, powertop, nano, vim
[translations]
korean translations (franco-c)
czech translation (Kynio89)
SCREENSHOTS
MRW1215
798
15
Hm. I've been running great on the AOKP 7/29 JB build, but the features in this ROM kinda make me want to flash this after work tonight. What's the MD5 for this ROM? I'm very much in the habit of checking that before flashing, and I don't see one listed in the thread (unless I missed it).
VAVA Mk2
364
12
Kinda took a gamble and flashed without getting an MD5. Will see if I can get one from Codenamedroid and add to the original post later today. Runs well so far with Franco.Kernel nightly 230. Seems like a good ROM to hold over until stable AOKP builds come out.
VAVA Mk2
364
12
Cool. Any glaring issues I should be aware of before flashing it?
Changing the lockscreen shortcuts can be laggy but so far nothing glaringly sticks out. Def worth flashing to check out. And yes, for those wondering, Codenamedroid gives credit this time to the stuff he kanged from AOKP and CM9/10 so let's give him a chance to redeem himself. So far this is solid!
JkdJedi
2,197
218
Don't know how he did it but as of now this is the premier rom out there right now, imo. Has all the goodies from Cm10 and AOKP and some xtra's (like weather pane at lockscreen).
I think CM10 And AOKP will be back on top soon. I flashed this and was very impressed when it first came out. Hopefully in the near future bygones will be bygones.
VAVA Mk2
364
12
Eh try for a bit. I had a few random reboots and dropped calls on this one today plus wifi was acting weird. Maybe I had a corrupted file but this has bugs. Once he works the kinks out, will be a front runner. Had to Nandroid back today during work :-\ I am going to try Bugless Beast or Jelly Bro tonight and use either until this or AOKP get stable builds.
chriscw81
170
5
Benn running it around 4 hours and haven't seen any problems yet. This was my go to rom back in the ICS days until it disappeared. Its good to see it back :)
VAVA Mk2
364
12
Maybe I will give it another go around at 3.1 or something. Not sure why I had the force restarts today. Was a bit annoying when I was on the phone for work with a manager and mid call my phone decided to reboot :-/. Still, this to was my go to back in the day. Love the amount of features. If he can get the stability up to what I thought was perfect in the 1.x verison, then I will possibly come back. Close tie between this and AOKP, although leaning moreso to AOKP. Ride the pink unicorn, baby!
VAVA Mk2
364
12
And like that...3.1.0 is out with new features. I will update the original post and thread title to reflect this and in addition put in info from the thread about the ROM and credits for it from Rootz Wiki for those interested. Let's see how my phone does tomorrow with this build over the first...
ohiomoto
705
111
The first JB (3.0.0) release didn't have much over Jelly Belly or Euroshank but 3.1.0 adds fastcharge mode and a few other nice bits. Running it since yesterday and seams to be running fine on my phone.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
The lockscreen weather has been on CM10 for weeks now, btw. :)
Reactions: 2defmouze
MRW1215
798
15
So I dirty flashed CNA from the 7/29 AOKP build, and things look to be running good. I'll give it a try for a couple days and see how it fares. Out of curiosity, is it possible to readjust the lockscreen clock/ info to the right side, rather than centered? I couldn't find that option in the lock screen settings.
ohiomoto
705
111
Funny because I dirty flashed from eruoshank. LOL I need to pick a ROM and do a full wipe, but until I decide (or have issues) I'm running dirty.
(Not sure about the lock screen settings.)
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Well considering it's mostly CM10 that's unsurprising ;)
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
ohiomoto
705
111
Yep, that's why I dirtied!
So far the only thing I really like about CNA over the Jelly Bro is the fast charge mode. Otherwise I think they both work fine. I had some issues using wifi toggles with Jelly Belly but liked it fine otherwise.
Overall, I feel I'm having a better user experience with the Jelly Bean ROMs over ICS.
MRW1215
798
15
Me, I just dirty flashed over AOKP (I made a backup before doing so) because I wasn't sure I was going to stay on CNA, and I figured if I ran into any issues from dirty flashing, I could just restore to my AOKP build, which was working just fine for me, anyway.
VAVA Mk2
364
12
Been running 3.1 since last night. Very smooth so far. Great experience. I consider this an "All-Star" game of ROMs as it has the best features from the best ROMs out there.
SOTK
244
62
This Rom is no longer at Rootzwiki. In fact, at this point, it does not exist on any forum. I believe he is still releasing the Rom on Google+ and there's rumor that he may go to DroidHive, but I haven't seen him there yet. I'm not sure how long Codename, aka BlackDroid, will be around. We'll see...
knowledge is power
