Hi all,
I have been having issues with the phone always saying it is charging and now it has decided it won't charge at all. I have tried multiple AC adaptors and multiple USB cables. I cant get the phone to pull up on the PC either as it says there was an error with the device.
I am currenly unlocked running JB. Is there a way lock and go back to stock without USB support? Can you send back a Nexus that is unlocked and rom'ed? I would normally never do this but I am not sure I have a choice as I can't use ADB or anything else. Phone is working otherwise.
Thanks
Thanks
