10-05-2012 05:29 AM
29 12
tools
  1. capnjb's Avatar
    I really need some help figuring this out. Here's the problem.
    I have tried everything to get Jelly Bean on my Nexus and all I get is the boot loop screen. I have flashed different ROMs multiple times, waited for hours with my phone in a boot loop, pushed buttons, and done battery pulls. I've even spent a whole day going completely back to stock, including having to re root, figuring this would solve the problem, and still all I get is the boot screen.
    Every ICS Rom I try boots up in 1-2 minutes with no problems.
    I wipe properly every time, system, davlic, cache. I can't figure this out. Am I the only person on the planet this is happening to? Normally this wouldn't be a big deal but no one is really supporting there ICS roms anymore. Just about everyone has gone to JB.
    Please HELP me!
    08-23-2012 09:06 AM
  2. AppleBonker's Avatar
    ICS ROMs work fine? What are you flashing for JB? As in which ROMs/gapps and where did you d/l them from? Checksums ok?
    2defmouze likes this.
    08-23-2012 09:10 AM
  3. dmmarck's Avatar
    Need details on what roms you were trying to flash and what you define as a bootloop.
    I also noticed you did not mention a data wipe/factory reset. This MUST be done. If this is done, and if all of the wipes are done, you will have absolutely no issue.
    I'll be sitting in here waiting .
    08-23-2012 09:13 AM
  4. wildman9904's Avatar
    Also, make sure whichever Rom you are flashing includes a kernel, or flash one in the same recovery session. Do this by opening the zip file (if you are using a browser on your phone, click extract and go to the folder it tells you it was extracted to) and look for a file called boot.img
    Swyped from the land of unicorn porn
    08-23-2012 09:16 AM
  5. dmmarck's Avatar
    Haven't seen one that doesn't, at least in toro land (thank god).
    Sent from my Nexus 7
    08-23-2012 09:40 AM
  6. bbudnick5001's Avatar
    Is it possible he's using the ICS boot loader and he's just not waiting long enough on the boot screen? If so maybe he should try the jb boot loader.
    08-23-2012 10:02 AM
  7. Nakrohtap's Avatar
    Even without the JB bootloader it should start. How do you re-root? I have heard of people locking their phones and unlocking again. Is that it? I am thinking too that a complete wipe is not being done. That way, the ICS structure is still in place and allows him to continuously flash ICS ROMs, but not JB ROMs. Maybe make a video of yourself doing the flashing process and post it?
    08-23-2012 10:10 AM
  8. bbudnick5001's Avatar
    It is also possible that he is not waiting long enough for it too boot. Remember when the first jb ROMs were out...it could take up to 10 minutes sometimes. Although this was never the case for me luckily.
    08-23-2012 11:12 AM
  9. Nakrohtap's Avatar
    Agreed. Also, there is no boot loop screen. If it's stuck in a boot loop, you will usually see the Google logo for a while, then the phone will restart, then the Google screen again over and over. The phone can also get stuck on the boot animation screen. These are 2 different issues.
    Sometimes just changing the kernel can fix this.
    08-23-2012 11:24 AM
  10. dmmarck's Avatar
    This
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
    08-23-2012 11:34 AM
  11. capnjb's Avatar
    Sorry I was away and not able to answer.
    As a last resort I used Wugs tool kit to reflash the stock rom and un root my device, it automaticaly does this. I then re rooted it using the tool kit.
    To be clear on wiping I followed all of the steps here, in post 3 I believe, Which included factory data reset, davlik wipe, cache wipe, I even wiped the battery stats along with my own butt.
    The boot screen I am talking about is the animation screen with the google X. It never moves past this screen. NOT the screen which says GOOGLE with the picture of the unlocked lock I go past that. So I guess its not technically a boot loop cause my phone doesn't boot back up it stays on the animation screen. I have left my phone for as long as 4 hours and it never moves past the boot animation. Normally I wait for 30 min to an hour before I pull the battery and restore and try again.
    I have tried Jelly belly, Codename, AOKP, Bugless, and a couple others I can't remember.
    Thanks for all your help.
    08-23-2012 06:58 PM
  12. dmmarck's Avatar
    And just so we're clear, you have a Verizon GNex and you're using proper VZW builds--aka toro?
    If you'd like, we can take you through the process. However, to say I'm not flummoxed would be an absolute understatement.
    08-23-2012 07:42 PM
  13. capnjb's Avatar
    You and me both! Like I said I think I'm the only one on the planet with this problem.
    Yes I have a verizon gnex.
    Kind of out of options now.
    Is there a difference between the ics boot loader and JB one? Do you think flashing a different kernel will help?
    08-23-2012 09:02 PM
  14. Nakrohtap's Avatar
    OP, are you still there? Many people have offered up suggestions or need more information from you in order to help you out. When you start a thread asking for help, you need to check back once in a while and respond.
    Update - No sooner do I put out the bat signal, he's back.
    Update #2 - my bad. Maybe if I refreshed to the last post...
    08-23-2012 09:12 PM
  15. Xanth269's Avatar
    DM is one of the best trouble shooters here in AC. He has helped me from the beginning and still gives me advice. I believe if your in a loop its a ROM issue not a kernel issue as you can flash a kernel without being in recovery. Is your gnx new or have you had it for sometime? If you used wugs to get back to stock and rerooted I would give it a shot again but don't sorry about using the jb bootloader until you get jb working. I have only flashed 3 job ROMs Jakes, Euro ***** and aokp. I am no expert but just some thoughts. Best of luck.
    08-23-2012 09:18 PM
  16. Xanth269's Avatar
    Quick question when in recovery what app you using TWRP or CWM maybe something wrong with the app or your cleaning/wiping order. Just a thought.
    08-23-2012 09:23 PM
  17. capnjb's Avatar
    I use CWM recovery to flash. I've never really used TWRP except for when the tool kit used it. I downloaded CWM right away after reverting to stock.
    My gnex isn't one of the first batch I picked it up in in the beginning of january
    I've been flashing roms since my Omnia, which I bricked once, and I have never had any problems like this.
    08-24-2012 02:09 AM
  18. capnjb's Avatar
    Yes he is that's why I'm on AC looking for help. He has helped me with several issues in the past, as have many others on this site.
    Thanks everyone for your help and brain storming.
    The only thing I haven't done is go back to stock and fully lock the phone. I just went to stock + unrooted. but I don't know if locking really has anything do do with it. I just can't figure out why it won't go past that boot animation. I flash the same way with every rom, Wipe everything, And They always load up.
    08-24-2012 02:19 AM
  19. dmmarck's Avatar
    If you can't boot a thing--nandroid, new rom, etc--I'd suggest locking the device and then unlocking it, if only to clear out anything on your SDcard that's causing this.
    08-24-2012 08:03 AM
  20. capnjb's Avatar
    OK I will try that. Can't do it till later. I'll post my results.
    08-24-2012 09:03 AM
  21. dmmarck's Avatar
    No worries. Let us know if you need any help!
    08-24-2012 09:03 AM
  22. capnjb's Avatar
    Ok Here's an update. I've spent the better part of the evening trying to get this to work and I still get stuck on the boot animation screen.
    I completely reverted back to stock including locking my device. I even did a factory reset before I unlocked it again. I did this two times because I realized after I started to flash JB I forgot to make an original nandroid so the only way out was to start all over again. I followed the steps to the letter wiping everything before flashing and still the same.
    I am looking at the Boot animation right now. I've been looking at it for the better part of an hour so I think it's safe to say this is a no go also. I guess I'll have to wait for Verizon to come out with an official update, If they ever do cause we baught a nexus and we should've had it before the S3 (total BS), which should solve the problem, Hopefully.
    If anyone has any other Ideas I'll try anything now short of throwing my Phone out the window to get a warranty replacement, I'm all ears.
    Thanks
    08-24-2012 07:43 PM
  23. dmmarck's Avatar
    If you want, I can walk you through step by step...but not tonight.
    08-24-2012 07:53 PM
  24. capnjb's Avatar
    Thank You I do appreciate it. I am going to go back to AOKP ICS for now. I am burned out on this. I don't know if I'm missing something but it's really crazy i've never seen this. Usually at least one will boot up but none of the jb roms work.
    Is there a separate partition I may be missing that doesn't get wiped even if you go back to stock? Like on my PC. I upgraded to win 7 and there is a partition that holds XP, Maybe something like that?
    I'm out of time for tonight anyway.
    Thanks again
    08-24-2012 10:15 PM
  25. dmmarck's Avatar
    Thanks again
    No. But if I'm there i can better get a handle on what's going on. Let me know, pm me if you'd like!
    08-24-2012 11:36 PM
29 12
