Hola amigos! I'm hoping someone can help me out a bit here. At the moment I'm running CNA 3.6 and Franco M5. I'm pretty sure I've had all of these mods working simultaneously in the past on different roms, but not definitively from these links. These are my most recent downloads saved to my dropbox. It seems I can only have either the AOKP weather icons OR the punisher lockscreen icon; same with the stock reflective icons OR the glow mods. Of course, I can't find the links that all worked together, but I assure you it was luck that I found ones that weren't overwriting the other. AOKP Build 2 worked no problem with the lockscreen icon. Too bad it doesn't have the mulitple targets or it'd probably be my daily driver. I'm sure that's soon to come. Anyway, any modders that could tell me how or what to change so that they do not overwrite? Thanks.
These are all zipthemer mods if you care to use them. Typical disclaimer etc.
http://db.tt/13rx9Xam - AOKP Weather
http://db.tt/PlAbRfUL - Punisher lockscreen icon
http://db.tt/SXluRUBU - Glow Mod Nexus
http://db.tt/OTz42we2 - Stock Reflective Softkeys
