Results 1 to 7 of 7
    Froojr's Avatar
    Posts
    Carrier
    Euroskank JellyBro/franco
    Question Battery life help wanted
    I'm running Euroskank Jellybro nightlies and franco kernel nightlies on a toro. I've seen people posting about their crazy long battery life, but no details about settings to get that sort of time on a charge. Min CPU what? max CPU what? What is undervolted, and to what amount? What governor? Things like this are what I need. Is there some sort of guide that I've missed that gives pointers on battery life and ROM/kernel settings?
  2. #2
    greyhd's Avatar
    Posts
    Global Posts
    651 Global Posts
    Default Re: Battery life help wanted
    Quote Originally Posted by Froojr View Post
    I'm also running the euroskank rom and have set cpu to on demand and best battery life is have seen is 15 hrs with 5 hrs of screen time. Others with crazy long battery life might be using wifi for the majority of the day and that drains the battery slower than using the network. If you want long battery life you can go through the forums or play with the settings themselves through franco's app. Good luck.
  3. #3
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    7,475 Global Posts
    Carrier
    BB JB
    you could also use the app juice defender. I bought the plus version when I had my DINC any only recently started using it again on my nexus.
    Works pretty well but takes a bit to reconnect to data when you unlock the phone.
  4. #4
    Bobaroo's Avatar
    Posts
    Carrier
    AOKP M5
    Quote Originally Posted by greyhd View Post
    Stock battery and CDMA Nexus???!!
    Froojr's Avatar
    Posts
    Carrier
    I'm almost afraid to just play with the settings in franco's app. I'd hate to undervolt one aspect a little and undervolt another part too much. I have no idea where to even begin when it comes to CPU settings to be safe and not chance frying the phone.
    So far, I've overclocked to 1305 MHz (1.3 GHz), set the ondemand governor, and am using the Balanced power mode. Undervolting is the main part of my concern. I like to tweak things, but one tweak too far or in the wrong direction could be fatal.
    Wait, I said I "set" the ondemand governor. I haven't changed any governor settings, just turned it on. Default was interactive. I'm not even sure which does what aka what the difference is.
  6. #6
    Buy a few power packs and charges for a couple rooms in the house and car, it'll be way more effective than trying to tweak things. Best case you'll see marginal increases and usually at the expense of performance.
  7. #7
    greyhd's Avatar
    Posts
    Global Posts
    651 Global Posts
    Quote Originally Posted by Bobaroo View Post
    Yes CDMA, but with the 2100 battery.
  1. Samsung Galaxy S Battery Life Help
    By Plinkfoyd in forum General Help and How To
    Last Post: 05-17-2013, 09:05 PM
  2. HATE my battery life HELP
    By jdtftp1 in forum Verizon Galaxy Nexus
    Last Post: 01-20-2012, 05:11 PM
  3. How to save battery life... HELP
    By jdtftp1 in forum Verizon HTC Rezound
    Last Post: 11-22-2011, 11:15 AM
  4. New SGS2 user gutted with battery life. HELP!!!
    By mpshah in forum Samsung Galaxy S II
    Last Post: 10-14-2011, 11:50 AM
  5. Battery Life Help!!
    By KMfiremedic111 in forum Samsung Transform
    Last Post: 12-08-2010, 04:48 AM
