HELP with TWRP
Xanth269
511
26
HELP HEP HELP
was in TWRP to check version as I see new version is out for the up coming 4.2 rom, well I hit the small square box in the middle and it started to verify filesystems and partition sizes... been like this for 10 minutes now... battery pull? or will is finish what it started?
THANKS!
EDIT- Never mind, battery pull and all is good.
Is there an easier way to update the TWRP files other than the .img file way?
2defmouze
3,945
1,552
Fastboot the updated .img, doesn't get much easier.... But if you're truly lazy then goomanager should be able to do it for you I believe.
BaMaDuDe87
159
I actually just dl'ed TWRP today to check it out and when I hit the middle button it did the same thing. I just hit it again after a few min and it went back to the home screen.
Xd3dp1gX
