Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By greyhd
    Default Help! Galaxy Nexus with CyanogenMod keeps cycling through boot process, but never turns on.
    Hi everyone. I'm not sure offhand which version of CyanogenMod I'm running, but I'm subscribed to the nightly updates, so it's probably the most recent one. After my phone ran out of batteries tonight, I went to go plug it in. After letting it charge for a bit, I decided to turn it on. What has been happening for the past hour is that it shows the Google logo, then goes to the CyanogenMod screen (the words with the circle rotating around it). After being in that screen for about 10-15 seconds, it stops, the screen turns off, the phone vibrates briefly (as if I were turning it on), and the process repeats. Any ideas? Thank you!
  2. #2
    greyhd's Avatar
    Posts
    Global Posts
    651 Global Posts
    Default Re: Help! Galaxy Nexus with CyanogenMod keeps cycling through boot process, but never turns on.
    Quote Originally Posted by temporaryaccount11 View Post
    Go into recovery and flash the rom and gapps again. What rom and gapps are you using? Turn off the phone the hold power and both volume up and down buttons until it boots up. You can use your volume rocker to scroll to recovery and power button to pick.
    ConTejas likes this.
    Hi! I was using CyanogenMod 10, but then I tried recovering to CyanogenMod 9, which did not work, but I now load up the CyanogenMod 9 boot screen. In addition, instead of continually restarting, now it is just frozen on the CyanogenMod 9 boot screen. I'm not sure which gapps I'm using...is there any way to check? I tried doing a clean wipe/factory reset, and I wiped the Davlik cache, but it didn't work. What else can I do? I'm very stuck here. Thanks!
  4. #4
    greyhd's Avatar
    Posts
    Global Posts
    651 Global Posts
    Use cm10 rom and gapps, then do a clean install.
  1. N4 or GALAXY NEXUS with LTE? (need help, from Mxico)
    By alexhp26 in forum Google Nexus 4
    Last Post: 11-08-2012, 03:27 PM
  2. HELP just own a gsm/hsdpa galaxy nexus with jelly bean 4.1.1 it doesnt work well.
    By trebontdroid in forum Google / Samsung Galaxy Nexus
    Last Post: 10-23-2012, 11:14 PM
  3. WIFI tether on unlocked Galaxy Nexus with AT&T?
    By hexproject in forum Google / Samsung Galaxy Nexus
    Last Post: 01-10-2012, 07:20 PM
  4. Sprint Ad Announces Galaxy Nexus with 1.5 GHz SoC
    By Tiko7523 in forum Google / Samsung Galaxy Nexus
    Last Post: 01-07-2012, 12:10 PM
  5. ICS Help/Galaxy Nexus User Guide
    By Cory Streater in forum Verizon Galaxy Nexus
    Last Post: 12-04-2011, 12:34 AM
