Results 1 to 15 of 15
    josequi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I wiped everything on my NEXUS! please help
    Hello All;
    I was going to update today to the latest cyanogenmod toro 10.0 and I wiped everything including the SD card that doesn't exist. Of course the image was lost and I cant access the SD card to a least copy the file there and install from recovery mode.
    Note: I can access Recovery Mode and of course Download mode
    Any help will be greatly appreciated
    Thanks
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Default Re: I wiped everything on my NEXUS! please help
    It may not be gone. Check to see if there is a 0 directory on your internal storage open it. There may be another 0 director and open that keep going till you find all your files
    From my Galaxy Note 2 via Tapatalk
    josequi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can't access anything on the phone but the Bootloader and Download mode, it is quite frustrating. My computer wont recognize the phone ( I guess ) when connected to Odin it always fail the installation. And don't know where to even begin looking for the directories.
  4. #4
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    You should be Able to get to recovery
  5. #5
    10001110101's Avatar
    Posts
    Global Posts
    397 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    There will be many...
    Sounds like Wug's toolkit is in order. It should let you flash factory images directly from the program itself.
    - - - Updated - - -
    Quote Originally Posted by DroidXcon View Post
    If we wiped his SD, he probably doesn't have anything left to flash in recovery.
  6. #6
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    He doesn't actually know if he wiped it because he cannot access it. So catch22 lol
    josequi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In the process of doing a clean install I wiped the dalkin, the data, factory reset and by mistake the sd card where my new rom was sitting, so I have nothing, I van access the recovery mode but or the download mode but my computer wont see the drive, Odin seems to communicate but wont flash the rom. always fails.
  8. #8
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Did it wipe the card when it wiped data. Because that's what I did and I thought everything was gone. But some how it created sub folders and buried my files. Did you look into wugs toolkit suggested above?
    josequi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wugu's toolkit where is it located, I have nothing to loose since I actually formatted everything
  10. Thread Author  Thread Author    #10
    josequi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Downloading Hope it works! Good luck to me! And Thanks all of you, i'll be posting my results.....
  11. #11
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Good luck hope it works out
  12. #12
    Posts
    Global Posts
    397 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Good luck!
  13. #13
    narrow_minded#WN's Avatar
    Posts
    Global Posts
    120 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Bugless Beast
    I just had something similar happen to me just now. Your SD card can't be recognized, right? Downloading Wugs as well to see what can be done.
  14. #14
    Posts
    Global Posts
    120 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Bugless Beast
    I couldn't figure out the Wugs thing, but I followed the "Return to Stock" sticky guide and it got me out of the bootloop. Maybe try that.
  15. #15
    HurrrDurrrDURP's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had this EXACT problem when I was trying to flash a ROM my first time I did this.
    Open up adb and type this in
    Code:
    adb push <Image location here> /data/media
    /data/media is where the SD card is mounted in Android, this will allow you to push the image to the phone and be able to flash it without first restoring then attempting again.
    Good luck!
  1. Auto Answer on my S3.....Please help?
    By mandajayinc in forum Sprint Galaxy S3
    Last Post: 09-04-2015, 09:02 AM
  2. Replies: 1
    Last Post: 01-17-2012, 12:19 AM
  3. Still unable to see device on my PC - Please HELP!
    By ochness in forum Verizon Fascinate
    Last Post: 04-01-2011, 11:02 AM
  4. What is going on with my gmail..please help
    By bugler in forum Motorola Droid X
    Last Post: 10-27-2010, 08:15 AM
  5. Screen Locks to quick on HTC HERO... please help
    By SUP3RSTAN in forum HTC Hero
    Last Post: 11-21-2009, 12:46 PM
