1. jean15paul's Avatar
    So I'm trying to improve my understanding of all things Android Rooting related, and I have questions about the "Fix Permissions" functionality in TWRP/CWM/Rom Manager etc.
    So I've done some searching and I think I have a basic understanding of what "Fix Permissions" does. It seems to make sure that the app.apk, app data, and app permissions all match up. I've read a few different articles/posts, but these are the most useful ones that I've found:
    [How to] Install and Use Clockworkmod Recovery w/Screen captures
    Fix permissions - CyanogenMod Wiki
    What I haven't found is any good thorough infomation about when you should fix permissions. I've seen some people say that they arbitrarily try it if they are having problems (force closes, ROM not behaving properly, etc). I've seen some people say they do it after every flash. Other have said that it's not necessary after a full wipe, but they do it after every dirty flash.
    So here are my questions:
    • When does it make sense to fix permissions?
    • Is there anytime that you shouldn't fix permissions?
    • Similarly, is there any danger in fixing permissions, or is it always safe to do?
    • From a technical standpoint, how does Fix Permissions know what data goes with what app?
    Thanks everyone for the help
    12-11-2012 11:24 AM
  2. 2defmouze's Avatar
    You shouldn't have to. It's a relic of an earlier time in custom ROM flashing. Some people still think you should or that it helps fix issues, but no. Lol.
    12-11-2012 11:41 AM
  3. jean15paul's Avatar
    I must admit that I'm a little skeptical of that. Only because, when I dirty flashed the CM10 12/4 nightly over the CM10 11/24 nightly, I had an issue. My phone wouldn't recognize that headphones were plugged in and would still play out of the external speaker; also the external speaker volume couldn't be changed. I tried a bunch of stuff and nothing fixed it. Then I tried "Fix Permissions" (in TWRP), and it seemed to resolve the problem.
    I'm not an expert, and it could have been something else, but that is was seemed to fix it.
    12-11-2012 01:32 PM
  1. GPS Problems Needed to Fix
    By mr.seth.price in forum U.S. Cellular Mesmerize
    Last Post: 01-02-2012, 10:35 AM
  2. When do I need to wipe cache, etc.?
    By evilhugbear in forum Sprint Nexus S 4G Rooting, ROMs, and Hacks
    Last Post: 08-29-2011, 06:56 PM
  3. Needed to "Fix Permissions" twice now...
    By paintdrinkingpete in forum Verizon HTC Thunderbolt
    Last Post: 07-04-2011, 07:26 PM
  4. What causes the need to fix permissions everytime I want to flash something?
    By dablitzkrieg in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 05-23-2011, 01:39 PM
  5. NS4G not allowing me to fix permissions
    By aalcantara89 in forum Sprint Nexus S 4G Rooting, ROMs, and Hacks
    Last Post: 05-19-2011, 02:37 PM
