Results 1 to 5 of 5
Like Tree1Likes
  • 2 Post By ConTejas
  • 1 Post By ConTejas
    dsuppa's Avatar
    Posts
    Global Posts
    165 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question CM 10.1 Nightly Data Issue and /0/0/0/0 folder
    So I updated from AOKP Build 5 to CM10.1 yesterday and my data connection just refuses to connect. After about 4 or 5 attempts and reflashing and full data wiping I gave up and went back to AOKP5. The only problem is now my directory structure is nested in a folder /0/0/0/0/0/sdcard ...... I'm guessing this has to do with the reflashing of 4.2.1 and profiles? Has anyone else had either issue or know how to fix them?
  2. #2
    ConTejas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Latest OS + EX kernel
    Default Re: CM 10.1 Nightly Data Issue and /0/0/0/0 folder
    Oh man, there's a ton of info on this, but I'll help ya out. 1) You MUST upgrade to the latest CWM or TWRP (ftw) that have been updated for 4.2.x. 4.2 brought a new tablet feature that allows for muliple users (hence your extra /0s). You might not have noticed the change if you were on the proper recovery. 2) I've found on many 4.2.x builds you must either enable data and/or change the network to CMDA/LTE, reboot into recovery, fix permissions, and then reboot to profit. Annoying, but it is what it is.
    2defmouze and dsuppa like this.
  3. #3
    CallerHoller's Avatar
    Posts
    Global Posts
    490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What is the fix permissions thing? I switch to lte/cdma reboot and all is fine.
    dsuppa's Avatar
    Posts
    Global Posts
    165 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks! Seem to be all good now.
  5. #5
    ConTejas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by CallerHoller View Post
    It's just an extra precautionary step after , to the best of my knowledge. I just do it after my ritual post rom/gapps flash of dsp manager, xyz kernel, and zipthemer mods.
    JkdJedi likes this.
  1. CM 10 Nightlies Having Issue with System UI constantly restarting/crashing
    By sethgoldstein in forum Google / Samsung Galaxy Nexus
    Last Post: 12-04-2012, 01:21 PM
  2. CM 10 Call Volume Issues
    By mrshickadance9 in forum Verizon Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 12-02-2012, 10:13 PM
  3. HELP What is the Proper way to install cm 10 nightlies?
    By xxGBlackx in forum HTC EVO 4G LTE Rooting, ROMs, and Hacks
    Last Post: 11-06-2012, 03:37 AM
  4. CyanogenMod 10 Nightly & M Build Change Log and Bug List
    By dano92580 in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 09-25-2012, 01:18 PM
  5. extra MMS text with every MMS? and data issue
    By owenrg in forum AT&T ATRIX
    Last Post: 03-18-2011, 01:26 PM
